DLSS Feature Proposal: Adaptive Spatial Resolution
Hi NVIDIA DLSS team, πŸ‘‹
I would like to propose a concept for future DLSS development: adaptive spatial resolution based on image complexity and reconstruction confidence.
Current DLSS Super Resolution generally uses one internal render scale for the entire frame. However, different regions of the image do not require the same amount of native spatial information. Large stable surfaces such as walls, roads, or sky can often be reconstructed well from a lower resolution, while thin geometry such as foliage, wires, fences, grass, and distant branches is much more sensitive to reduced sampling and may produce shimmering or temporal instability.
My idea is to use a dynamic importance/confidence map that controls local sampling density. Difficult regions could receive native or even supersampled detail, while simple and stable regions could be rendered at a lower resolution. DLSS would then reconstruct the final image using this heterogeneous input together with motion vectors, depth, temporal history, and reconstruction confidence.
The main challenge would be preventing visible transitions between regions, so the sampling density would likely need to change smoothly and temporally rather than through hard resolution boundaries.
The goal is not only higher FPS, but a more efficient use of the GPU rendering budget: spend real samples where DLSS needs them most, and save work where neural reconstruction is already reliable.
In theory, this could allow a frame with an average rendering cost closer to 1440p while preserving near-4K stability in the most visually sensitive regions.
I would be interested to know whether NVIDIA has explored a similar direction for future DLSS or neural rende
ring research.
