I am evaluating authentic DLSS Neural Rendering in a standalone Windows D3D12 renderer using my own CUSTOM project identity. I need help identifying the supported SDK/runtime combination and the official NR D3D12 integration contract.
Measured setup:
- GeForce RTX 5060 Ti; NVIDIA driver 621.01; Windows build 26200.
- Public NVIDIA/DLSS SDK commit 9981c6350dc58c0ce21f024fd65e31e851c31689, generic API 0x15, x64 Release/MD.
- nvsdk_ngx_d.lib SHA256: bc43df9ec032004fde681d3e3afd01cde239e03a0125b822e88674c84287f99c.
- NR definitions from the publicly distributed RTX Remix ngx_sdk_dlnr version 2 package.
- NR runtime 310.9.16, 266424944 bytes, SHA256: 2bc19bc09a7b89dd44f73e2ac0108fcc586e2154bdd0830f242f4f040e28789f.
- Own ProjectID: eee84e75-e706-4a13-9476-ce71885cbb89; engine CUSTOM.
Observed results:
- A pre-Init NVSDK_NGX_D3D12_GetFeatureRequirements call for feature 18 returned Success=1, support mask 0, minimum OS string 10.0.0 and minimum hardware-architecture value 432. The requested runtime path and file hash were observed after the call.
- In earlier creation-only runs, initialization and capability queries completed, but NVSDK_NGX_D3D12_GetScratchBufferSize returned PlatformError 0xBAD00002. The size remained zero and was treated as invalid. Create and Evaluate were not attempted.
- Read-only instrumentation of our own process observed a rejection branch involving the calling module identity. An uninstrumented control also returned the error. We are not concluding that renaming a module is a valid solution or that this alone proves an application-registration issue.
- Our own renderer now produces real geometric color/depth/motion/material/UI resources and verifies GPU readbacks, but it does not yet execute NR. We will adapt its conventions only to a confirmed compatible NR contract.
Could you clarify:
- Is this public SDK library intended to create NR D3D12 with that runtime and an own CUSTOM project? If not, what complete package/revision should be used, and how can an independent developer legitimately obtain it?
- Is application registration or specific enablement required? If so, what is the official process for our own identity?
- Can you provide the compatible nvsdk_ngx_helpers_dlssnr_d3d.h, or equivalent official documentation and a minimal D3D12 Create/Evaluate example? The inspected NR package includes Vulkan helpers but not that D3D helper.
- What input formats, color/motion/depth conventions, scratch rules, states, queue/fence ordering and resource lifetimes apply to this revision?
We can provide a minimal source reproducer and sanitized receipts. No NVIDIA binaries, models, private SDK contents or game-account data are attached to this initial question. This request concerns a standalone renderer; any later integration with a protected game would require its publisher’s separate approval.
