DLSS4 frame generation cannot be used in streaming
I use sunshine+moonlight for streaming
The streaming device is iPad Pro 2021 12.9 (supports up to 120hz)
The computer graphics card is 5070ti
As shown in the figure, when I turn on frame generation, the frame rate detected by the PC is 106, but the frame rate of the streaming device screen is 51.97. There may be a little delay error between the two data, but basically the streaming device still displays the original frame rate of my game (if I turn off frame generation, the screen frame rate of my iPad is the same as the PC game frame rate), so I did not enjoy the frame rate generated by DLSS4 frame, so I wonder if this problem cannot be solved due to the implementation principle or can it be improved through software upgrades?
