Answer for your above 5 question:
- i tried all 3 possible things.
a) src, dst ,desc in Host memory ( As IDT switch recommends it to be possible)
b) src and desc in host memory and dst in NT shared partition
c) desc in host memory and src , dst from bar ( NT shared partition)
All there are not working .
First of all if i set dummy descriptor and stride descriptor which is recommended by IDT itself is failing .It does not do a transfer.It just set descriptor. First setting descriptor with host memory need to be solved.
- refer this link for all support for IDT DMA
https://www.idt.com/document/apn/714-dma-pcie-switches
I see this error in DMA controller of IDT ( DMA status register )
Tried all possible combination. See answer 1
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1) (prog-if 00 [Normal decode])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 409
Bus: primary=00, secondary=01, subordinate=02, sec-latency=0
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: 51000000-53ffffff
Prefetchable memory behind bridge: 0000000058000000-0000000059ffffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Kernel driver in use: pcieport
01:00.0 PCI bridge: Integrated Device Technology, Inc. [IDT] PES32NT8AG2 (rev 02) (prog-if 00 [Normal decode])
Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Bus: primary=01, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: fff00000-000fffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Capabilities: [40] Express (v2) Upstream Port, MSI 00
DevCap: MaxPayload 2048 bytes, PhantFunc 0
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
LnkCap: Port #8, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <4us, L1 <4us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; Disabled- CommClk-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
Capabilities: [c0] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v2] Advanced Error Reporting
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
Capabilities: [200 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [320 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir+ CmpltRedir+ UpstreamFwd- EgressCtrl- DirectTrans+
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
01:00.1 Bridge: Integrated Device Technology, Inc. [IDT] PES32NT8AG2 (rev 02)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin D routed to IRQ 440
Region 0: Memory at 51000000 (64-bit, non-prefetchable)
Region 2: Memory at 58000000 (64-bit, prefetchable)
Region 4: Memory at 52000000 (64-bit, non-prefetchable)
Capabilities: [40] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 0000000266258000 Data: 0001
Capabilities: [330 v1] #12
Kernel driver in use: idt-g2-ntb
01:00.2 System peripheral: Integrated Device Technology, Inc. [IDT] PES32NT8AG2 (rev 02)
Latency: 0
Interrupt: pin C routed to IRQ 439
Region 0: Memory at 51001000 (64-bit, non-prefetchable)
Address: 0000000266258000 Data: 0000
Kernel driver in use: idt-g2-dma
13e10000.host1x 13e10000.host1x:ctx4 15100000.tsecb 15500000.tsec 15830000.se 2993000.adsp 3180000.i2c 3210000.spi 3530000.xhci c250000.i2c
13e10000.host1x:ctx0 13e10000.host1x:ctx5 15340000.vic 15600000.isp 15840000.se 3100000.serial 3190000.i2c 3240000.spi 3550000.xudc c260000.spi
13e10000.host1x:ctx1 13e10000.host1x:ctx6 15380000.nvjpg 15700000.vi 17000000.gp10b 3110000.serial 31b0000.i2c 3400000.sdhci b000000.rtcpu c280000.serial
13e10000.host1x:ctx2 13e10000.host1x:ctx7 15480000.nvdec 15810000.se 2490000.ether_qos 3130000.serial 31c0000.i2c 3460000.sdhci c1a0000.aon d000000.bpmp
13e10000.host1x:ctx3 150c0000.nvcsi 154c0000.nvenc 15820000.se 2600000.dma 3160000.i2c 31e0000.i2c 3507000.ahci-sata c240000.i2c smmu_test
DMA Memory - idt_dev->dma_local_mem: vaddr ffffffc07c102000 bus_addr 00000000fc102000 size 0x00001000
[ 67.025889] DMA Memory -Single vaddr 00000000fc102000
I tried to use this physical address for DMA desc and tried immediate transfer .Still same issue
SMMU is disabled . So i used physical address
Later question:
Yes for both function 1 and function 2 of the IDT switch pci_enable_device() is done.
