lspci -t
t186:/ # lspci -t
-[0000:00]—01.0-[01]----00.0
start msg:
[ 3.252175] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.254209] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.254549] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 3.254557] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[ 3.254563] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[ 3.254569] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.254573] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 3.254915] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.255452] PCIE: ASPM not enabled
[ 3.255490] pci 0000:00:01.0: BAR 8: assigned [mem 0x50400000-0x50ffffff]
[ 3.255498] pci 0000:01:00.0: BAR 1: assigned [mem 0x50800000-0x50ffffff]
[ 3.255508] pci 0000:01:00.0: BAR 0: assigned [mem 0x50400000-0x504fffff]
[ 3.255518] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 3.255529] pci 0000:00:01.0: bridge window [mem 0x50400000-0x50ffffff]
[ 3.255679] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 3.255683] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.255897] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 -> Gen-2
in my device driver, use pci_alloc_consisten alloc dma buffer, and set the dma_bus_addr to device side, device use this address to write data to this buffer,occur error:
pcieport 0000:00:01.0: AER: Multiple Uncorrected (Fatal) error received: id=0020
ctx->virt_addr = pci_alloc_consistent(pdev,DMA_SIZE,&ctx->dma_bus_addr);
if (NULL == ctx->virt_addr)
ret = -ENOMEM;
iounmap(ctx->mem_bar);
iounmap(ctx->reg_bar);
p_reg_base = NULL;
p_mem_base = NULL;
printk(KERN_ERR"pci_alloc_consistent fail...\n");
goto free_map;
printk(KERN_ERR"alloc dma vir addr = 0x%08lx, dma bus addr = 0x%08lx\n",ctx->virt_addr,ctx->dma_bus_addr);
[ 504.023699] hello,welcome to module init…
[ 504.028040] fpga_video_probe…
[ 504.031419] Welink FPGA Video 0000:01:00.0: enabling device (0000 -> 0002)
[ 504.038370] device support 64 bits DMA
[ 504.042238] IO BAR barnum = 0 start = 0x50400000 end = 0x504fffff mem_len = 0x100000
[ 504.050098] MEM BAR barnum = 1 start = 0x50800000 end = 0x50ffffff mem_len = 0x800000
[ 504.059810] alloc dma vir addr = 0xffffff8001281000, dma bus addr = 0x80d00000
[ 504.067048] force ulval = 0xfc400000
[ 504.070668] dma buffer phys addr = 0xffffffc081281000
[ 504.077934] FPGA video init OK…
how can I fix it ?
