DNNPlugin: INT32 is not yet supported AND Assertion failed: d.nbDims >= 1 ../rtSafe/safeHelpers.cpp:91 Aborting
Hi, i try to generate bin from onnx using tensorrt_optimizer and add plugins, here’s my command
/home/tyan/workspace/driveworks-jafar/driveworks-4.0/tools/dnn/tensorRT_optimization --pluginConfig=/home/tyan/workspace/driveworks-jafar/driveworks-4.0/samples/src/dnn/plugin_dir/plugin.json  --modelType=onnx --onnxFile=/home/tyan/workspace/driveworks-jafar/driveworks-4.0/samples/src/dnn/plugin_dir/pfe_baseline32000_sim.onnx --out=/home/tyan/workspace/driveworks-jafar/driveworks-4.0/samples/src/dnn/plugin_dir/pfe_baseline32000_sim.bin
But it returns error
[10-06-2023 16:52:41] ModelImporter.cpp:108: Parsing node: Tile_16 [Tile]
[10-06-2023 16:52:41] ModelImporter.cpp:124: Searching for input: 37
[10-06-2023 16:52:41] ModelImporter.cpp:124: Searching for input: 34
[10-06-2023 16:52:41] ModelImporter.cpp:130: Tile_16 [Tile] inputs: [37 -> ()], [34 -> (3)],
[10-06-2023 16:52:41] ModelImporter.cpp:140: No importer registered for op: Tile. Attempting to import as plugin.
[10-06-2023 16:52:41] builtin_op_importers.cpp:2191: Searching for plugin: Tile, plugin_version: 1, plugin_namespace:
Getting plugin version
Getting plugin namespace
Getting plugin field collection
Creating plugin
Deserializing from field collection
[10-06-2023 16:52:41] builtin_op_importers.cpp:2208: Successfully created plugin: Tile
Getting num outputs
Num outputs: 1
[10-06-2023 16:52:41] DNNPlugin: INT32 is not yet supported.
Getting output precision
Cloning plugin
Getting num outputs
Num outputs: 1
Destroying plugin
Destroyed plugin
[10-06-2023 16:52:41] ImporterContext.hpp:122: Registering layer: Tile_16 for ONNX node: Tile_16
[10-06-2023 16:52:41] Assertion failed: d.nbDims >= 1
Aborting...
terminate called after throwing an instance of 'nvinfer1::AssertionFailure'
  what():  std::exception
Aborted (core dumped)
Any idea what is causing the problem and how to solve it?
Notes: I cant upgrade the tensorrt
Here’s my plugin and onnx file
pfe_baseline32000_sim.onnx (39.8 KB)
TilePlugin.cu (16.4 KB)
libdnn_tile_plugin_tpat.so (743.2 KB)
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
Where is the ‘plugin.json’ file? Thanks.
its okay, i solved it.
Found that the previous layer’s shape not defined correctly. Thanks
