Do concurrent does not auto collapse if explicit shape dummy array and procedure call is present
nvfortran: do concurrent auto-collapse is silently disabled when an explicit-shape array dummy is bounded by a derived-type component AND the loop body contains a procedure call.
Four variants of the SAME 2-D stencil. They differ only in
  • where the array dummy’s bounds come from, and
  • whether the loop body calls a procedure or is written inline.
Expected: all four map the 2-D iteration space to one thread per cell. Actual : variant C does not collapse – it maps j to blocks and i to 128 threads, so each thread serially walks 32 cells at nx=4096. I can get around this using openacc but it’d be cool if do concurrent did it too. Changing the array bounds to plain integers helps but it doesn’t fix it entirely.
Build: nvfortran -O2 -stdpar=gpu -gpu=cc70,mem:separate -Minfo=stdpar,accel -c repro.f90
Compiler: nvfortran 26.5-0 (also seen on 25.5), CUDA 12.9, Tesla V100 (cc70).
module repro_m
   use, intrinsic :: iso_fortran_env, only: wp => real64
   implicit none
   type :: grid_t
      integer :: nx_total = 0, ny_total = 0, nghost = 1
   end type grid_t
contains
   ! The called leaf. Trivial, pure, side-effect free.
   pure subroutine cell(a, nx, ny, i, j, r)
      integer, intent(in) :: nx, ny, i, j
      real(wp), intent(in) :: a(nx, ny)
      real(wp), intent(out) :: r
      r = 2.5_wp*a(i, j) + a(i - 1, j) - a(i + 1, j)
   end subroutine cell
   ! A. bounds from plain integer dummies + CALL      -> collapses (OK)
   pure subroutine a_plain_call(a, c, nx, ny)
      real(wp), intent(out) :: c(nx, ny)
      integer :: i, j
      real(wp) :: r
      do concurrent(j=2:ny - 1, i=2:nx - 1) local(r)
         call cell(a, nx, ny, i, j, r)
         c(i, j) = r
      end do
   end subroutine a_plain_call
   ! B. bounds from grid%component + INLINE body      -> collapses (OK)
   pure subroutine b_dt_inline(a, c, grid)
      type(grid_t), intent(in) :: grid
      real(wp), intent(in) :: a(grid%nx_total, grid%ny_total)
      real(wp), intent(out) :: c(grid%nx_total, grid%ny_total)
      integer :: i, j, nx, ny
      real(wp) :: r
      nx = grid%nx_total; ny = grid%ny_total
         c(i, j) = r
      end do
   end subroutine b_dt_inline
   ! C. bounds from grid%component + CALL      -> *** DOES NOT COLLAPSE ***
   !    Identical maths to A and B. Only the combination differs.
   pure subroutine c_dt_call(a, c, grid)
      real(wp) :: r
         c(i, j) = r
      end do
   end subroutine c_dt_call
   ! D. THE WORKAROUND: same as C, but the bounds are passed as plain
   !    integers alongside the derived type. Collapses again.
   pure subroutine d_workaround(a, c, nx, ny, grid)
      integer :: i, j, ng
      real(wp) :: r
      ng = grid%nghost
      do concurrent(j=1 + ng:ny - ng, i=1 + ng:nx - ng) local(r)
         c(i, j) = r
      end do
   end subroutine d_workaround
end module repro_m
program repro
   use, intrinsic :: iso_fortran_env, only: wp => real64, int64, output_unit
   use repro_m
   implicit none
   integer, parameter :: NX = 4096, NY = 4096, NREP = 50
   type(grid_t) :: grid
   real(wp), allocatable :: a(:, :), c1(:, :), c2(:, :), c3(:, :), c4(:, :)
   real(wp) :: t0, t1, ms_a, ms_b, ms_c, ms_d, dmax
   integer :: i, j, r
   grid%nx_total = NX; grid%ny_total = NY; grid%nghost = 1
   allocate (a(NX, NY), c1(NX, NY), c2(NX, NY), c3(NX, NY), c4(NX, NY))
   do concurrent(j=1:NY, i=1:NX)
      a(i, j) = real(i, wp) + 0.5_wp*real(j, wp)
   end do
   c1 = 0.0_wp; c2 = 0.0_wp; c3 = 0.0_wp; c4 = 0.0_wp
   !$acc enter data copyin(a) create(c1, c2, c3, c4)
   call a_plain_call(a, c1, NX, NY); !$acc wait
   t0 = wall(); do r = 1, NREP; call a_plain_call(a, c1, NX, NY); end do
   !$acc wait
   t1 = wall(); ms_a = (t1 - t0)*1000.0_wp/NREP
   call b_dt_inline(a, c2, grid); !$acc wait
   t0 = wall(); do r = 1, NREP; call b_dt_inline(a, c2, grid); end do
   !$acc wait
   t1 = wall(); ms_b = (t1 - t0)*1000.0_wp/NREP
   call c_dt_call(a, c3, grid); !$acc wait
   t0 = wall(); do r = 1, NREP; call c_dt_call(a, c3, grid); end do
   !$acc wait
   t1 = wall(); ms_c = (t1 - t0)*1000.0_wp/NREP
   call d_workaround(a, c4, NX, NY, grid); !$acc wait
   t0 = wall(); do r = 1, NREP; call d_workaround(a, c4, NX, NY, grid); end do
   !$acc wait
   t1 = wall(); ms_d = (t1 - t0)*1000.0_wp/NREP
   !$acc update self(c1, c2, c3, c4)
   !$acc exit data delete(a, c1, c2, c3, c4)
   ! all four compute the same thing
   dmax = 0.0_wp
   do j = 2, NY - 1
      do i = 2, NX - 1
         dmax = max(dmax, abs(c1(i, j) - c3(i, j)), abs(c1(i, j) - c2(i, j)), &
                    abs(c1(i, j) - c4(i, j)))
      end do
   end do
   write (output_unit, '(a,i0,a,i0,a,i0,a)') 'grid ', NX, ' x ', NY, ', ', NREP, ' reps'
   write (output_unit, '(a)') repeat('-', 64)
   write (output_unit, '(a,f9.4,a)') '  A  plain bounds  + call    : ', ms_a, ' ms   [collapses]'
   write (output_unit, '(a,f9.4,a)') '  B  grid% bounds  + inline  : ', ms_b, ' ms   [collapses]'
   write (output_unit, '(a,f9.4,a)') '  C  grid% bounds  + call    : ', ms_c, ' ms   *** NO COLLAPSE ***'
   write (output_unit, '(a,f9.4,a)') '  D  workaround (plain dims) : ', ms_d, ' ms   [collapses]'
   write (output_unit, '(a,f6.2,a)') '  C is ', ms_c/ms_a, 'x slower than A (same maths)'
   write (output_unit, '(a,es10.3,a)') '  max |difference| between all four: ', dmax, '  (0 = identical)'
   deallocate (a, c1, c2, c3, c4)
contains
   function wall() result(t)
      real(wp) :: t
      integer(int64) :: cnt, rate
      call system_clock(cnt, rate)
      t = real(cnt, wp)/real(rate, wp)
   end function wall
end program repro
Hi Jorge,
I looks to me that the problem is that i and j are getting passed to the call by reference (default in Fortran) which is preventing the auto-collapse. The simple fix is to pass them by value:
      integer, intent(in),value :: nx, ny, i, j
   end subroutine cell
c_dt_call:
     61, Generating NVIDIA GPU code
         61,   ! blockidx%x threadidx%x auto-collapsed
             Loop parallelized across CUDA thread blocks, CUDA threads(128) collapse(2) ! blockidx%x threadidx%x
     61, Generating implicit copyin(a(:,:)) [if not already present]
         Generating implicit copyout(c(2:nx-1,2:ny-1)) [if not already present]
Hope this helps,
Mat
