Do concurrent
I am trying to learn how to use do concurrent in fortran. I wrote a basic example, but I don’t understand how to manage total sums:
    do concurrent(i=1:n)
       x(i)=real(i)*0.000137d0
       y(i)=real(i)*0.000029d0
    enddo
    tot=0.0d0
    do concurrent(i=1:n) reduce (+:tot)
       y(i) = x(i)+y(i)+sin(x(i)*y(i))
       tot=tot+y(i)
    enddo
    print*,sum(y)/real(n),tot/real(n)
The final “tot” is not the same as sum(y). What is the right way to use it?
Thanks,
Stefano
Hi Stefano,
The syntax looks ok. How different are the two sums?
Parallel reductions will give slightly differing results over a serial reduction. Floating point calculations have a rounding error, so when order of the operations changes, the rounding error changes and hence will give different results.
If the results are very different, please provide a reproducing example that I can build and run.
-Mat
Thank you, the results are quite different. Here the code and the output:
program test
integer :: n=1000000000
real, allocatable :: x(:),y(:)
real :: tot
allocate(x(n),y(n))
    enddo
    tot=0.0d0
       tot=tot+y(i)
    enddo
end program
I compile with: nvfortran -O1 -o inizio -stdpar=gpu -Minfo=all -mp=gpu -gpu=cc89 t.f90
Output: 4398.046 83000.00
Thanks,
Stefano
The program is overflowing the default REAL (single precision). Use “real(kind=8)” or add the “-r8” flag to use double precision.
% nvfortran -stdpar=gpu test.F90 -r8
% a.out
    83000.00006749529         83000.00006759127
Yes, it works, thank you very much!
Stefano
