: Jetson Nano • DeepStream Version
: DeepStream 5.0 SDK • JetPack Version (valid for Jetson only)
: Jetpack 4.4.1 • Issue Type( questions, new requirements, bugs)
deepstream-app Inference • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
I ran it on DeepStream 5.0 with the config.txt file I used in Deepstream 4.0.
Do you have a config file configured with DeepStream 5.0?
Does the custom(tlt).engine file ran on DeepStream4.0.1 work with DeepStream 5.0?
You can use the same TLT file with Deepstream 5.0.
However, since the TensorRT engine file is not portable, please recreate it on the Deepstream 5.0 environment.
Yes. The error indicates you are using an engine file created from another TensorRT version.
To solve this issue, please recreate the engine on the target platform directly.
More clearly, you don’t need to retrain the model but bring the original file rather than the compiled engine.
For example, in your use case, please use the xxxxx.caffemodel and xxxxx.prototxt model instead.
Once the engine file is not available, Deepstream will automatically generate the xxxxx.engine for the target.
