Do I need a Physical Graphics Card for building and flashing our Orin Dev Kit?
I see there is only Graphics Driver needed but Graphics Card in Installation
But I still need to confirm the neediness of Graphics Card
If yes, then what’s the minimum recommended requirenments of NV Graphics Cards? Such the size of graphics memory and the architecture and so on.
Dear @Keelung,
You require graphics card on host in case you plan to run DRIVE OS, DW samples on host. If you plan to use the host just for flashing and compiling, You do not require any GPU.
