Do I need to use a 120W (12v 10a, etc...) adapter to get the maximum performance of the Xavier nx 8gb model?
Do I need to use a 120W (12v 10a, etc…) adapter to get the maximum performance of the Xavier nx 8gb model?
Download nvpmodel.conf from power estimator and attach it.
Which power adapter should I use for maximum performance?
nvpmodel.conf (6.2 KB)
Thank you.
Hi, per module datasheet, the Supported Power Modes: 10W |15W | 20W.
I just want to add that good power regulation is important, and if a lower power supply fails, then likely it is regulation, not total current capacity.
