Hi all, do Jetson Orin Nano support PCIe hotplug?
In my application, I am using Realtek RTS5261 (PCIe 3.0 Complicant Card Reader Controller) as a bridge for SD Card access through Jetson’s PCIe port. Based on Realtek’s datasheet, in order to use the Realtek’s chip, system support to PCIe hot plug is necessary. The BIOS also has to enable PCIe hot plug relative option. Example: you have to enable PCIe port hot plug and native PCIe.
Sorry for the late response.
We are not able to experiment as the hardware that integrating the Jetson with the Realtek Card reader is not ready yet. Does the Jetson Orin Nano support PCIe hotplug?
No, it does not support hotplug.
