Do not find "config_aiaa.json" file
I encounter a problem when I deploy my own model to server.
In the tutorial of https://docs.nvidia.com/clara/aiaa/tlt-mi-ai-an-sdk-getting-started/index.html#aiaa_byom, there should be “config_aiaa.json” in my docker environment. But I didn’t find it. I have tried command
find / -name config_aiaa.json
Hope to get some helps. Thanks!
Best,
pengbol
the config_aiaa.json is under the config directory of the MMAR. Perhaps you can try using any of the models on NGC as a template for your own model; here’s an example MMAR:
https://ngc.nvidia.com/catalog/models/nvidia:med:segmentation_mri_brain_tumors_br16_full/files
