Do not restart after executing the command”sudo nv_update_engine –install”
I have compiled OTA upgrade package(bl_update_payload), opened “Update and Redundancy A/B”, and I exec command “sudo nv_update_engine --install”, now the system resumes after 10s. I want to control whether to restart, is there A way to realize this?
Or, how can I prevent it from restarting, except by using “ctrl+c”?
BR,
I use Jetpack4.4 , L4T R32.4.3, could I use the command " nv_update_engine --install no-reboot"?
thanks!
BR,
Yes, it will work.
Hi WayneWWW,
Thanks for your replay!
Is the code for the “nv_update_engine” plan public?
Is there a plan to expose program code?
BR,
AFAIK, there is no plan for it now. Sorry about that.
Okay, thanks.
Last one , are there any other extension parameters?
BR,
You can use --help in the application and it will show all the parameters.
