From the page 1 of Jetson_Orin_Nano_DevKit_Carrier_Board_Specification_SP-11324-001_v1.1.pdf, the eDP list in Display Controller.
Do Orin NX and Orin nano support eDP ?
Actually we suggest to use DP as Orin Nano devkit carrier board design.
Why ?
Is there any known issue by using eDP ?
For software development we use DP output, so it is more stable. And our developer kit uses DP, we have more experience in DP output, and may be able to provide further suggestion.
eDP is hardware spec and supposed to work, but there may be potential issues. When you hit certain issue, we may not be able to suggest further, and you would need to check more on your own.
We would suggest use DP output.
Got it, appreciate.
