do pgi fortran supports cula ?
vs2010+pgi fortran
configure the environment
1.globle setting
select tools>options>project and solutions>pvf directories,configure global exextable,include,and library paths
2.project setting
configuration properties>linker>input. in the additional dependences field ,enter “libcula_pgfortan.lib”
3.runtime path
copy cula.dlland its’s dlls to the working directory
but when i run the program there are errors::like this
SourceFile1.obj : error LNK2019: unresolved external symbol _CULA_INITIALIZE@0 referenced in function MAIN
SourceFile1.obj : error LNK2019: unresolved external symbol _CULA_SGEQRF@20 referenced in function MAIN
SourceFile1.obj : error LNK2019: unresolved external symbol _CULA_SHUTDOWN@0 referenced in function MAIN
SourceFile1.obj : error LNK2019: unresolved external symbol _CULA_GETERRORINFO@0 referenced in function _CHECK_STATUS@4
SourceFile1.obj : error LNK2019: unresolved external symbol _CULA_GETSTATUSSTRING@4 referenced in function _CHECK_STATUS@4
can you help me?
Hi Lyh,
Try the following settings instead:
  1. Linker | General | Additional Library Directories
Put the path to the CULA library directory
  1. Linker | Input | Additional Dependencies
Put the name of the CULA library, i.e., libcula_pgfortran.lib
  1. Debugging | Environment
Add the path to the CULA DLLs to the PATH environment variable.
For example, set this property to PATH=newpath;%PATH%
Hope this helps,
Mat
Thanks for your help
I had done according your suggestions,but it still have errors
1)Linker | General | Additional Library Directories
C:\Program Files\cula\lib
  2. Debugging | Environment(add"C:\Program Files\cula\bin"to the enviromrnt variable which is named"cula_bin_path_32")
    %cula_bin_path_32%
Is there somthing wrong?
