do seq loop
Hi everyone,
I’m using Accelerator on a MD code. But I found that the result is somehow not updated at each timestep.
I simplified my code as following:
program seqloop
implicit none
integer::i,j,k,f(10)
integer::ff(10)
ff=0
f=0
!$acc data region copyin(f),copy(ff)
!$acc region
!$acc do seq
do k=1,2
   do j=1,10
      ff(j)=f(j)*2
   end do
   do i=1,10
      f(i)=i
   end do
end do
!$acc end region
!$acc end data region
write(*,*)ff
end program
The output of “ff” is a zero vector. However, if i change the “k loop” to “do host”, the result is correct.
Can anyone point out my mistake in the code?
I got a reply from PGI technical support by email.
This problem is fixed in the 10.8 release.
Thanks for all of your help and concern.
