You have showed how to install ROS on PX2 which is also available on web. Since building on PX2 is not possible do you have plans to provide guide how to set up ROS on host for cross build? Currently there is not clear resource for that. I am working on it now.
Related topics
Topic | Replies | Views | Activity | |
How to build self-made ROS packages for Xavier? | 2 | 741 | October 12, 2021 | |
Is it not possible to install and use ros2 locally on jetson nano? Is there any answer other than docker container? | 2 | 957 | March 11, 2022 | |
How to compile nad cross compile code that involves both ROS and DriveWorks code? | 0 | 625 | August 11, 2017 | |
How to make sure I installed ROS correctly on TX2 | 1 | 401 | July 22, 2019 | |
How to build cross-compilation of sample code including ROS? | 5 | 1819 | December 17, 2018 | |
Driveworks shared library for DRIVE PX2 to use with ROS to build code directly in DRIVE PX2 | 1 | 607 | February 26, 2019 | |
ROS2 Installation in Jetson Orin NX | 5 | 597 | June 26, 2024 | |
Any working cross compiling approach using docker? | 7 | 343 | March 4, 2024 | |
How to build sample code on Drive PX2 target? | 8 | 3359 | September 17, 2018 | |
Installing ROS on Drive AGX Xavier | 4 | 854 | October 12, 2021 |
