Hi: Which document describes the flow of the display system of kernel?
Please refer to the TX1 TRM (Technical reference manual) on the download center.
Thank you, WaybeWWW
Could you provide the document name about TX1 TRM?
please check
BTW, this is not direct doc for “kernel”. It is the structure of the display controller.
You need to understand the structure first so that you can know what is the driver code doing…
Thank you, I had learned drm framework, I’ll learn tegra display from drm
Tegra display and DRM are two different concepts actually…
