As in Installation Using DRIVE OS Docker Containers
Should be -q
but -g
Dear @Keelung,
Yes. It is -q instead of -g. We will get it fixed.
And even -g fixed, then got SHELL: command not found
Since SHELL is just an environment variable, not a command.
So $SHELL
should be used instead of $(SHELL)
Dear @Keelung,
Could you check using wget -qO- https://get.docker.com/ | ${SHELL}
${SHELL} works.
