Hi ;
from rpm file
https://www.mellanox.com/downloads/DOCA/DOCA_v3.2.0/host/doca-host-3.2.0-125000_25.10_ol9.x86_64.rpm
Problem: package doca-ofed-3.2.0-125000.x86_64 from doca requires xpmem-dkms >= 2510.0.16-1.el9, but none of the providers can be installed
[root@localhost doca]# dnf info doca-ofed
Last metadata expiration check: 0:08:56 ago on Fri 12 Dec 2025 01:35:07 AM EST.
Available Packages
Version : 3.2.0
Release : 125000
Architecture : x86_64
Source : doca-ofed-3.2.0-125000.src.rpm
Repository : doca
Summary : A doca-host profile that contains driver-only packages, similar to former mlnx_ofed
URL : https://www.nvidia.com/
License : BSD
Description : DOCA doca-ofed meta-package
[root@localhost doca]# sudo dnf clean all
10 files removed
[root@localhost doca]# sudo dnf -y install doca-ofed
DOCA 3.2.0-125000 82 MB/s | 84 kB 00:00
DOCA 3.2.0-125000 SOURCE 251 kB/s | 257 B 00:00
Error:
conflicting requests
nothing provides dkms >= 3.2 needed by xpmem-dkms-2510.0.16-1.el9.x86_64 from doca
(try to add ‘–skip-broken’ to skip uninstallable packages or ‘–nobest’ to use not only best candidate packages)
