Hello, I am running into an issue with DOCA DPA with the doca_dpa_dev_sync_event_update_add() function.
I have run create_doca_dpa_completion_sync_event() on the host, received the completion event handle, passed it to a thread on DPA, but when I run doca_dpa_dev_sync_event_update_add() on the handle I keep getting this error:
[4160887] process_call 601 - Fatal error (0x2) on RPC polling
[00:07:28:077570][2773807008][DOCA][ERR][dpa_launcher.cpp:842] Flexio RPC failed
[00:07:28:077591][2773807008][DOCA][ERR][dpa_kernel_launch_sample.c:404][kernel_launch] Failed to trigger threads via RPC: DOCA Driver call failure
[00:07:30:081979][2773807008][DOCA][ERR][dpa_kernel_launch_main.c:96][main] kernel_launch() encountered an error: DOCA Driver call failure
[4160887] heap_destroy 377 - Failed to destroy heap, not all device heap memory was freed
[4160887] flexio_process_destroy 1303 - Failed to release prm heap memory
[4160887] flexio_process_destroy 1310 - Failed to destroy process PRM object (err = 22)
[00:07:30:093116][2773807008][DOCA][ERR][dpa_runtime.cpp:564] Flexio process destroy failed
[00:07:30:252746][2773807008][DOCA][INF][dpa_kernel_launch_main.c:114][main] Sample finished with errors
It runs fine if I were to substitute doca_dpa_dev_sync_event_update_add() with doca_dpa_dev_sync_event_update_set() instead, but I need the add function for thread barrier synchronization. I haven’t found any resources online. Does anyone know why this is happening specifically for this add function?
Thank you
