DOCA eth_l2_fwd Example Application Fails on BlueField-3 ARM Host
Hi NVIDIA Community,
I’m experiencing issues running DOCA SDK example applications on a BlueField-3 ARM host and would appreciate any help or guidance.
Issue Description
I’m trying to run the eth_l2_fwd example application on the BlueField-3 ARM host, but it fails during initialization with errors related to port polling and pipe creation.
The command and logs are following:
ubuntu@localhost:/tmp/build/eth_l2_fwd$ sudo ./doca_eth_l2_fwd -d mlx5_0,mlx5_1
[10:16:19:885728][3513391][DOCA][WRN][doca_mmap.cpp:2026][mmap_set_memrange] Mmap 0xaaab0051af00: Memory range isn't aligned to 64B - addr=0xffff900fb010. For best performance using CPU memory
, align address to 64B (cache-line size). For best performance using GPU memory, align address to 64KB (page size)
[10:16:19:890912][3513391][DOCA][WRN][engine_model.c:94][adapt_queue_depth] adapting queue depth to 128.
EAL: Detected CPU lcores: 16
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/3513391/mp_socket
EAL: Selected IOVA mode 'VA'
TELEMETRY: No legacy callbacks, legacy socket not created
EAL: Probe PCI driver: mlx5_pci (15b3:a2dc) device: 0000:03:00.0 (socket -1)
mlx5_net: port 0: TX queue 0 not yet set up
mlx5_net: port 0: TX queue 1 not yet set up
mlx5_net: port 0: TX queue 2 not yet set up
mlx5_net: port 0: TX queue 3 not yet set up
mlx5_net: port 0: TX queue 4 not yet set up
mlx5_net: port 0: TX queue 5 not yet set up
mlx5_net: port 0: TX queue 6 not yet set up
mlx5_net: port 0: TX queue 7 not yet set up
mlx5_net: port 0: TX queue 8 not yet set up
mlx5_net: port 0: TX queue 9 not yet set up
mlx5_net: port 0: TX queue 10 not yet set up
mlx5_net: port 0: TX queue 11 not yet set up
mlx5_net: port 0: TX queue 12 not yet set up
mlx5_net: port 0: TX queue 13 not yet set up
mlx5_net: port 0: TX queue 14 not yet set up
mlx5_net: port 0: TX queue 15 not yet set up
mlx5_net: Port 0 Rx queue 0 was not set up
[10:16:20:792383][3513391][DOCA][ERR][hws_port.c:3597][hws_port_set_poll_mark] failed allowing poll for mark on port 0
[10:16:20:792402][3513391][DOCA][ERR][engine_pipe.c:678][engine_pipe_create] failed creating pipe - build failed rc=(-19)
[10:16:20:792778][3513391][DOCA][ERR][doca_flow.c:2095][doca_flow_pipe_create] engine pipe creation failed, rc = -19
[10:16:20:792811][3513391][DOCA][ERR][eth_rxq_common.c:204][create_root_pipe] Failed to create doca flow pipe, err: DOCA_ERROR_DRIVER
[10:16:20:792827][3513391][DOCA][ERR][eth_rxq_common.c:276][allocate_eth_rxq_flow_resources] Failed to allocate eth_rxq_flow_resources: failed to create root pipe, err: DOCA_ERROR_DRIVER
[10:16:20:801777][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801806][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801815][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801821][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801831][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801839][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801845][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801852][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801859][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801864][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801876][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801898][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801907][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801913][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:20:801922][3513391][DOCA][CRT][hws_port.c:3822][vnf_def_fdb_pop_completion_cb] default rule pop completion status failed
[10:16:22:071425][3513391][DOCA][ERR][eth_l2_fwd_core.c:820][eth_l2_fwd_execute] Failed to allocate ETH RXQ flow resources for device 1: DOCA Driver call failure
[10:16:22:071458][3513391][DOCA][ERR][eth_l2_fwd.c:468][main] Failed to execute Ethernet L2 Forwarding Application: DOCA Driver call failure
[10:16:22:071951][3513391][DOCA][ERR][doca_dpdk.cpp:476][priv_doca_dpdk_dev_as_port] DPDK bridge failed to find port id for device=0xaaab005122f0
[10:16:22:071969][3513391][DOCA][ERR][doca_dpdk.cpp:493][priv_doca_dpdk_dev_get_port_metadata] Failed to get port metadata: port_id was not found
[10:16:22:071983][3513391][DOCA][ERR][doca_eth_rxq.c:1506][eth_rxq_stop_cpu_ctx] ETH_RXQ 0xaaab00b802f0: Failed to stop eth_rxq: failed to unmap external RQ from a dpdk queue. err=DOCA_ERROR_NOT_FOUND
[10:16:22:071991][3513391][DOCA][ERR][doca_pe.cpp:1096][stop_context] Progress engine 0xaaab0051ad40: Failed to stop ctx=0xaaab00b802f0
[10:16:22:072003][3513391][DOCA][ERR][doca_ctx.cpp:652][priv_doca_ctx_set_state_to_idle] CTX 0xaaab00b802f0 failed to stop with status DOCA_ERROR_NOT_FOUND
[10:16:22:072010][3513391][DOCA][ERR][eth_l2_fwd_core.c:906][eth_l2_fwd_cleanup] Failed to stop device 1 ETH RXQ DOCA CTX: Requested Resource Not Found
[10:16:22:072017][3513391][DOCA][ERR][eth_l2_fwd.c:475][main] Failed to clean up Ethernet L2 Forwarding Application resources: Requested Resource Not Found
This is the likely starting point of the error.
The same error occurs with other receive-based implementations that use the eth_rxq_common.c in the samples/doca_eth/ directory.
Device Information
  • mlxfwmanager
ubuntu@localhost:~$ sudo mlxfwmanager -d /dev/mst/mt41692_pciconf0
Querying Mellanox devices firmware ...
Device #1:
  Device Type:      BlueField3
  Part Number:      900-9D3B6-00CV-A_Ax
  Description:      NVIDIA BlueField-3 B3220 P-Series FHHL DPU; 200GbE (default mode) / NDR200 IB;
                    Dual-port QSFP112; PCIe Gen5.0 x16 with x16 PCIe extension option;
                    16 Arm cores; 32GB on-board DDR; integrated BMC; Crypto Enabled
  PSID:             MT_0000000884
  PCI Device Name:  /dev/mst/mt41692_pciconf0
  Base MAC:         a088c281aad4
  Versions:         Current        Available
     FW             32.44.1036     N/A
     PXE            3.7.0500       N/A
     UEFI           14.37.0014     N/A
     UEFI Virtio blk   22.4.0014      N/A
     UEFI Virtio net   21.4.0013      N/A
  Status:           No matching image found
  • mlxconfig
Device #1:
Device type:        BlueField3
Description:        NVIDIA BlueField-3 B3220 P-Series FHHL DPU; 200GbE (default mode) / NDR200 IB; Dual-port QSFP112; PCIe Gen5.0 x16 with x16 PCIe extension option; 16 Arm cores; 32GB on-board DDR; integrated BMC; Crypto Enabled
Device:             /dev/mst/mt41692_pciconf0
Configurations:                                          Next Boot
        MODULE_SPLIT_M0                             Array[0..15]
        MODULE_SPLIT_M1                             Array[0..15]
        LARGE_MTU_TWEAK_64                          False(0)
        AES_XTS_TWEAK_INC_64                        False(0)
        CRYPTO_POLICY                               UNRESTRICTED(1)
 RO     CUSTOMIZATION_NUMBER                        Array[0..15]
        DPA_AUTHENTICATION                          False(0)
        NVME_EMULATION_ENABLE                       False(0)
        NVME_EMULATION_NUM_VF                       0
        NVME_EMULATION_NUM_PF                       1
        NVME_EMULATION_VENDOR_ID                    5555
        NVME_EMULATION_DEVICE_ID                    24577
        NVME_EMULATION_CLASS_CODE                   67586
        NVME_EMULATION_REVISION_ID                  0
        NVME_EMULATION_SUBSYSTEM_VENDOR_ID          0
        NVME_EMULATION_SUBSYSTEM_ID                 0
        NVME_EMULATION_NUM_MSIX                     0
        NVME_EMULATION_NUM_VF_MSIX                  0
        NVME_EMULATION_MAX_QUEUE_DEPTH              0
        PCI_SWITCH_EMULATION_NUM_PORT               16
        PCI_SWITCH_EMULATION_ENABLE                 False(0)
        UPT_EMULATION_ENABLE                        False(0)
        VIRTIO_BLK_EMULATION_ENABLE                 False(0)
        VIRTIO_BLK_EMULATION_NUM_VF                 0
        VIRTIO_BLK_EMULATION_NUM_PF                 0
        VIRTIO_BLK_EMU_SUBS_VENDOR_ID               6900
        VIRTIO_BLK_EMULATION_SUBSYSTEM_ID           4162
        VIRTIO_BLK_EMULATION_NUM_MSIX               2
        VIRTIO_BLK_EMULATION_NUM_VF_MSIX            0
        VIRTIO_FS_EMULATION_ENABLE                  False(0)
        VIRTIO_FS_EMULATION_NUM_VF                  0
        VIRTIO_FS_EMULATION_NUM_PF                  0
        VIRTIO_FS_EMU_SUBSYSTEM_VENDOR_ID           6900
        VIRTIO_FS_EMULATION_SUBSYSTEM_ID            4186
        VIRTIO_FS_EMULATION_NUM_MSIX                2
        VIRTIO_FS_EMULATION_NUM_VF_MSIX             0
        VIRTIO_NET_EMULATION_ENABLE                 False(0)
        VIRTIO_NET_EMULATION_NUM_VF                 0
        VIRTIO_NET_EMULATION_NUM_PF                 0
        VIRTIO_NET_EMU_SUBSYSTEM_VENDOR_ID          6900
        VIRTIO_NET_EMULATION_SUBSYSTEM_ID           4161
        VIRTIO_NET_EMULATION_NUM_MSIX               2
        VIRTIO_NET_EMULATION_NUM_VF_MSIX            0
        HOST_PRIV_FLASH_ACCESS                      DEVICE_DEFAULT(0)
        HOST_PRIV_NV_HOST                           DEVICE_DEFAULT(0)
        HOST_PRIV_NV_PORT                           DEVICE_DEFAULT(0)
        HOST_PRIV_NV_GLOBAL                         DEVICE_DEFAULT(0)
        HOST_PRIV_NV_INTERNAL_CPU                   DEVICE_DEFAULT(0)
        HOST_PRIV_PCC_UPDATE                        DEVICE_DEFAULT(0)
        HOST_PRIV_FW_UPDATE                         DEVICE_DEFAULT(0)
        HOST_PRIV_NIC_RESET                         DEVICE_DEFAULT(0)
        FLEX_PARSER_PROFILE_ENABLE                  0
        PROG_PARSE_GRAPH                            False(0)
        FLEX_IPV4_OVER_VXLAN_PORT                   0
        SWITCH_COMPT_FEATURE_MASK                   0x0(0)
        PF_BAR2_SIZE                                3
        INTERNAL_CPU_RSHIM                          ENABLED(0)
        PF_NUM_OF_VF_VALID                          False(0)
        NON_PREFETCHABLE_PF_BAR                     False(0)
        VF_VPD_ENABLE                               False(0)
        PF_NUM_PF_MSIX_VALID                        False(0)
        PER_PF_NUM_SF                               False(0)
        STRICT_VF_MSIX_NUM                          False(0)
        VF_NODNIC_ENABLE                            False(0)
        NUM_PF_MSIX_VALID                           True(1)
        NUM_OF_VFS                                  16
        NUM_OF_PF                                   2
        PF_BAR2_ENABLE                              True(1)
        HIDE_PORT2_PF                               False(0)
        SRIOV_EN                                    True(1)
        PF_LOG_BAR_SIZE                             5
        VF_LOG_BAR_SIZE                             1
        NUM_PF_MSIX                                 63
        NUM_VF_MSIX                                 11
        PCIE_CREDIT_TOKEN_TIMEOUT                   0
        PCI_DOWNSTREAM_PORT_OWNER                   Array[0..15]
        STRAP_SD_OR_MH                              False(0)
        OFF_BOARD_SERIALIZER                        False(0)
        PCORE2_REVERSAL                             False(0)
        PCORE1_REVERSAL                             False(0)
        PCORE0_REVERSAL                             False(0)
        PCI_BUS01_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS01_SWITCH_INDEX                      0
        PCI_BUS01_SPEED                             PCI_GEN_1(0)
        PCI_BUS01_ASPM                              False(0)
        PCI_BUS01_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS00_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS00_SWITCH_INDEX                      0
        PCI_BUS00_SPEED                             PCI_GEN_1(0)
        PCI_BUS00_ASPM                              False(0)
        PCI_BUS00_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS03_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS03_SWITCH_INDEX                      0
        PCI_BUS03_SPEED                             PCI_GEN_1(0)
        PCI_BUS03_ASPM                              False(0)
        PCI_BUS03_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS02_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS02_SWITCH_INDEX                      0
        PCI_BUS02_SPEED                             PCI_GEN_1(0)
        PCI_BUS02_ASPM                              False(0)
        PCI_BUS02_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS05_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS05_SWITCH_INDEX                      0
        PCI_BUS05_SPEED                             PCI_GEN_1(0)
        PCI_BUS05_ASPM                              False(0)
        PCI_BUS05_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS04_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS04_SWITCH_INDEX                      0
        PCI_BUS04_SPEED                             PCI_GEN_1(0)
        PCI_BUS04_ASPM                              False(0)
        PCI_BUS04_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS07_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS07_SWITCH_INDEX                      0
        PCI_BUS07_SPEED                             PCI_GEN_1(0)
        PCI_BUS07_ASPM                              False(0)
        PCI_BUS07_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS06_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS06_SWITCH_INDEX                      0
        PCI_BUS06_SPEED                             PCI_GEN_1(0)
        PCI_BUS06_ASPM                              False(0)
        PCI_BUS06_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS11_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS11_SWITCH_INDEX                      0
        PCI_BUS11_SPEED                             PCI_GEN_1(0)
        PCI_BUS11_ASPM                              False(0)
        PCI_BUS11_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS10_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS10_SWITCH_INDEX                      0
        PCI_BUS10_SPEED                             PCI_GEN_1(0)
        PCI_BUS10_ASPM                              False(0)
        PCI_BUS10_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS13_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS13_SWITCH_INDEX                      0
        PCI_BUS13_SPEED                             PCI_GEN_1(0)
        PCI_BUS13_ASPM                              False(0)
        PCI_BUS13_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS12_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS12_SWITCH_INDEX                      0
        PCI_BUS12_SPEED                             PCI_GEN_1(0)
        PCI_BUS12_ASPM                              False(0)
        PCI_BUS12_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS15_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS15_SWITCH_INDEX                      0
        PCI_BUS15_SPEED                             PCI_GEN_1(0)
        PCI_BUS15_ASPM                              False(0)
        PCI_BUS15_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS14_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS14_SWITCH_INDEX                      0
        PCI_BUS14_SPEED                             PCI_GEN_1(0)
        PCI_BUS14_ASPM                              False(0)
        PCI_BUS14_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS17_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS17_SWITCH_INDEX                      0
        PCI_BUS17_SPEED                             PCI_GEN_1(0)
        PCI_BUS17_ASPM                              False(0)
        PCI_BUS17_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS16_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS16_SWITCH_INDEX                      0
        PCI_BUS16_SPEED                             PCI_GEN_1(0)
        PCI_BUS16_ASPM                              False(0)
        PCI_BUS16_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS21_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS21_SWITCH_INDEX                      0
        PCI_BUS21_SPEED                             PCI_GEN_1(0)
        PCI_BUS21_ASPM                              False(0)
        PCI_BUS21_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS20_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS20_SWITCH_INDEX                      0
        PCI_BUS20_SPEED                             PCI_GEN_1(0)
        PCI_BUS20_ASPM                              False(0)
        PCI_BUS20_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS23_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS23_SWITCH_INDEX                      0
        PCI_BUS23_SPEED                             PCI_GEN_1(0)
        PCI_BUS23_ASPM                              False(0)
        PCI_BUS23_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS22_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS22_SWITCH_INDEX                      0
        PCI_BUS22_SPEED                             PCI_GEN_1(0)
        PCI_BUS22_ASPM                              False(0)
        PCI_BUS22_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS25_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS25_SWITCH_INDEX                      0
        PCI_BUS25_SPEED                             PCI_GEN_1(0)
        PCI_BUS25_ASPM                              False(0)
        PCI_BUS25_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS24_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS24_SWITCH_INDEX                      0
        PCI_BUS24_SPEED                             PCI_GEN_1(0)
        PCI_BUS24_ASPM                              False(0)
        PCI_BUS24_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS27_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS27_SWITCH_INDEX                      0
        PCI_BUS27_SPEED                             PCI_GEN_1(0)
        PCI_BUS27_ASPM                              False(0)
        PCI_BUS27_WIDTH                             PCI_INACTIVE(0)
        PCI_BUS26_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
        PCI_BUS26_SWITCH_INDEX                      0
        PCI_BUS26_SPEED                             PCI_GEN_1(0)
        PCI_BUS26_ASPM                              False(0)
        PCI_BUS26_WIDTH                             PCI_INACTIVE(0)
        PCI_SWITCH1_UPSTREAM_PORT_PEX               0
        PCI_SWITCH1_UPSTREAM_PORT_BUS               0
        PCI_SWITCH0_UPSTREAM_PORT_PEX               0
        PCI_SWITCH0_UPSTREAM_PORT_BUS               0
        PCI_SWITCH2_UPSTREAM_PORT_PEX               0
        PCI_SWITCH2_UPSTREAM_PORT_BUS               0
        ROCE_CC_DCQCN_COMPATIBILITY_MODE            DEVICE_DEFAULT(0)
        ROCE_CC_STEERING_EXT                        DISABLED(1)
        ROCE_CC_LEGACY_DCQCN_SW                     False(0)
        HOST_CHAINING_MODE                          DISABLED(0)
        HOST_CHAINING_CACHE_DISABLE                 False(0)
        HOST_CHAINING_DESCRIPTORS                   Array[0..7]
        HOST_CHAINING_TOTAL_BUFFER_SIZE             Array[0..7]
        RDE_DISABLE                                 False(0)
        PLDM_FW_UPDATE_DISABLE                      False(0)
        RBT_DISABLE                                 False(0)
        PCIE_SMBUS_DISABLE                          False(0)
        PCIE_IN_BAND_VDM_DISABLE                    False(0)
        SM_DISABLE                                  False(0)
        LOG_DCR_HASH_TABLE_SIZE                     11
        MAX_PACKET_LIFETIME                         0
        DCR_LIFO_SIZE                               16384
        INTERNAL_CPU_MODEL                          EMBEDDED_CPU(1)
        INTERNAL_CPU_PAGE_SUPPLIER                  ECPF(0)
        INTERNAL_CPU_ESWITCH_MANAGER                ECPF(0)
        INTERNAL_CPU_IB_VPORT0                      ECPF(0)
        INTERNAL_CPU_OFFLOAD_ENGINE                 ENABLED(0)
        ESWITCH_HAIRPIN_DESCRIPTORS                 Array[0..7]
        ESWITCH_HAIRPIN_TOT_BUFFER_SIZE             Array[0..7]
        MEMIC_BAR_SIZE                              0
        MEMIC_SIZE_LIMIT                            _256KB(1)
        MEMIC_ATOMIC                                MEMIC_ATOMIC_ENABLE(2)
        PCC_NP_HANDLE_CORE_UTIL                     DEVICE_DEFAULT(0)
        PCC_HANDLE_CORE_UTIL                        DEVICE_DEFAULT(0)
        PCC_INT_NP_RTT_DSCP                         26
        PCC_INT_NP_RTT_DSCP_EN                      False(0)
        PCC_INT_NP_RTT_DATA_MODE                    RTT_V0(64)
        PCC_INT_EN                                  False(0)
        PCC_INT_SYSTEM_RTT                          0
        STEERING_CACHE_REFRESH                      0
        TX_SCHEDULER_LOCALITY_MODE                  DEVICE_DEFAULT(0)
        ICM_CACHE_MODE                              DEVICE_DEFAULT(0)
        TX_SCHEDULER_FWS_REACTIVITY                 DIRECT(1)
        HAIRPIN_DATA_BUFFER_LOCK                    False(0)
        TX_SCHEDULER_BURST                          0
        ZERO_TOUCH_TUNING_ENABLE                    False(0)
        TX_PCI_DATA_FETCH_LATENCY                   40
        RT_PPS_ENABLED_ON_POWERUP                   False(0)
        LAG_RESOURCE_ALLOCATION                     DEVICE_DEFAULT(0)
        ACCURATE_TX_SCHEDULER                       False(0)
        PARTIAL_RESET_EN                            False(0)
        RESET_WITH_HOST_ON_ERRORS                   False(0)
        USER_PROGRAMMABLE_CC                        False(0)
        ROCE_NEXT_PROTOCOL                          254
        LOG_MAX_QUEUE                               17
        LOG_MAX_OUTSTANDING_READ_ATOMIC             0
        MULTIPATH_DSCP                              DEVICE_DEFAULT(0)
        SWP_L4_CHECKSUM_MODE                        DEVICE_DEFAULT(0)
        CQE_COMPRESSION                             BALANCED(0)
        IP_OVER_VXLAN_EN                            False(0)
        MKEY_BY_NAME                                False(0)
        PRIO_TAG_REQUIRED_EN                        False(0)
        UCTX_EN                                     True(1)
        REAL_TIME_CLOCK_ENABLE                      False(0)
        RDMA_SELECTIVE_REPEAT_EN                    False(0)
        PCI_ATOMIC_MODE                             PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
        TUNNEL_ECN_COPY_DISABLE                     False(0)
        LRO_LOG_TIMEOUT0                            6
        LRO_LOG_TIMEOUT1                            7
        LRO_LOG_TIMEOUT2                            8
        LRO_LOG_TIMEOUT3                            13
        LOG_TX_PSN_WINDOW                           9
        VF_MIGRATION_MODE                           DEVICE_DEFAULT(0)
        LOG_MAX_OUTSTANDING_WQE                     7
        ROCE_ADAPTIVE_ROUTING_EN                    False(0)
        TUNNEL_IP_PROTO_ENTROPY_DISABLE             False(0)
        INT_LOG_MAX_PAYLOAD_SIZE                    AUTOMATIC(0)
        KEEP_ETH_LINK_UP_P1                         True(1)
        KEEP_IB_LINK_UP_P1                          False(0)
        KEEP_LINK_UP_ON_BOOT_P1                     False(0)
        KEEP_LINK_UP_ON_STANDBY_P1                  False(0)
        DO_NOT_CLEAR_PORT_STATS_P1                  False(0)
        AUTO_POWER_SAVE_LINK_DOWN_P1                False(0)
        KEEP_ETH_LINK_UP_P2                         True(1)
        KEEP_IB_LINK_UP_P2                          False(0)
        KEEP_LINK_UP_ON_BOOT_P2                     False(0)
        KEEP_LINK_UP_ON_STANDBY_P2                  False(0)
        DO_NOT_CLEAR_PORT_STATS_P2                  False(0)
        AUTO_POWER_SAVE_LINK_DOWN_P2                False(0)
        PHY_AUTO_NEG_P1                             DEVICE_DEFAULT(0)
        PHY_RATE_MASK_OVERRIDE_P1                   False(0)
        PHY_FEC_OVERRIDE_P1                         DEVICE_DEFAULT(0)
        PHY_AUTO_NEG_P2                             DEVICE_DEFAULT(0)
        PHY_RATE_MASK_OVERRIDE_P2                   False(0)
        PHY_FEC_OVERRIDE_P2                         DEVICE_DEFAULT(0)
        LLDP_NB_DCBX_P1                             False(0)
        LLDP_NB_RX_MODE_P1                          OFF(0)
        LLDP_NB_TX_MODE_P1                          OFF(0)
        LLDP_NB_DCBX_P2                             False(0)
        LLDP_NB_RX_MODE_P2                          OFF(0)
        LLDP_NB_TX_MODE_P2                          OFF(0)
        DCBX_IEEE_P1                                True(1)
        DCBX_CEE_P1                                 True(1)
        DCBX_WILLING_P1                             True(1)
        DCBX_IEEE_P2                                True(1)
        DCBX_CEE_P2                                 True(1)
        DCBX_WILLING_P2                             True(1)
        DUP_MAC_ACTION_P1                           LAST_CFG(0)
        MPFS_MC_LOOPBACK_DISABLE_P1                 False(0)
        MPFS_UC_LOOPBACK_DISABLE_P1                 False(0)
        UNKNOWN_UPLINK_MAC_FLOOD_P1                 False(0)
        SRIOV_IB_ROUTING_MODE_P1                    LID(1)
        DUP_MAC_ACTION_P2                           LAST_CFG(0)
        MPFS_MC_LOOPBACK_DISABLE_P2                 False(0)
        MPFS_UC_LOOPBACK_DISABLE_P2                 False(0)
        UNKNOWN_UPLINK_MAC_FLOOD_P2                 False(0)
        SRIOV_IB_ROUTING_MODE_P2                    LID(1)
        NUM_OF_VL_P1                                _4_VLs(3)
        NUM_OF_TC_P1                                _8_TCs(0)
        NUM_OF_PFC_P1                               8
        VL15_BUFFER_SIZE_P1                         0
        QOS_TRUST_STATE_P1                          TRUST_PCP(1)
        ETS_SCHED_MODE_P1                           device_default(0)
        VL_BUFFER_ALLOCATION_P1                     FULL_DYNAMIC(1)
        NUM_OF_VL_P2                                _4_VLs(3)
        NUM_OF_TC_P2                                _8_TCs(0)
        NUM_OF_PFC_P2                               8
        VL15_BUFFER_SIZE_P2                         0
        QOS_TRUST_STATE_P2                          TRUST_PCP(1)
        ETS_SCHED_MODE_P2                           device_default(0)
        VL_BUFFER_ALLOCATION_P2                     FULL_DYNAMIC(1)
        ROCE_CC_PRIO_MASK_P1                        255
        ROCE_CC_CNP_MODERATION_P1                   DEVICE_DEFAULT(0)
        ROCE_CC_SHAPER_COALESCE_P1                  DEVICE_DEFAULT(0)
        IB_CC_SHAPER_COALESCE_P1                    DEVICE_DEFAULT(0)
        ROCE_CC_PRIO_MASK_P2                        255
        ROCE_CC_CNP_MODERATION_P2                   DEVICE_DEFAULT(0)
        ROCE_CC_SHAPER_COALESCE_P2                  DEVICE_DEFAULT(0)
        IB_CC_SHAPER_COALESCE_P2                    DEVICE_DEFAULT(0)
        CLAMP_TGT_RATE_AFTER_TIME_INC_P1            True(1)
        CLAMP_TGT_RATE_P1                           False(0)
        RPG_TIME_RESET_P1                           300
        RPG_BYTE_RESET_P1                           32767
        RPG_THRESHOLD_P1                            1
        RPG_MAX_RATE_P1                             0
        RPG_AI_RATE_P1                              5
        RPG_HAI_RATE_P1                             50
        RPG_GD_P1                                   11
        RPG_MIN_DEC_FAC_P1                          50
        RPG_MIN_RATE_P1                             1
        RATE_TO_SET_ON_FIRST_CNP_P1                 0
        DCE_TCP_G_P1                                1019
        DCE_TCP_RTT_P1                              1
        RATE_REDUCE_MONITOR_PERIOD_P1               4
        INITIAL_ALPHA_VALUE_P1                      1023
        MIN_TIME_BETWEEN_CNPS_P1                    4
        CNP_802P_PRIO_P1                            6
        CNP_DSCP_P1                                 48
        CLAMP_TGT_RATE_AFTER_TIME_INC_P2            True(1)
        CLAMP_TGT_RATE_P2                           False(0)
        RPG_TIME_RESET_P2                           300
        RPG_BYTE_RESET_P2                           32767
        RPG_THRESHOLD_P2                            1
        RPG_MAX_RATE_P2                             0
        RPG_AI_RATE_P2                              5
        RPG_HAI_RATE_P2                             50
        RPG_GD_P2                                   11
        RPG_MIN_DEC_FAC_P2                          50
        RPG_MIN_RATE_P2                             1
        RATE_TO_SET_ON_FIRST_CNP_P2                 0
        DCE_TCP_G_P2                                1019
        DCE_TCP_RTT_P2                              1
        RATE_REDUCE_MONITOR_PERIOD_P2               4
        INITIAL_ALPHA_VALUE_P2                      1023
        MIN_TIME_BETWEEN_CNPS_P2                    4
        CNP_802P_PRIO_P2                            6
        CNP_DSCP_P2                                 48
        ROCE_RTT_RESP_DSCP_P1                       0
        ROCE_RTT_RESP_DSCP_MODE_P1                  DEVICE_DEFAULT(0)
        ROCE_RTT_RESP_DSCP_P2                       0
        ROCE_RTT_RESP_DSCP_MODE_P2                  DEVICE_DEFAULT(0)
        LINK_TYPE_P1                                ETH(2)
        LINK_TYPE_P2                                ETH(2)
        ECPF_ESWITCH_MANAGER                        ECPF(1)
        ECPF_PAGE_SUPPLIER                          ECPF(1)
        PORT_OWNER                                  True(1)
        ALLOW_RD_COUNTERS                           True(1)
        RENEG_ON_CHANGE                             True(1)
        TRACER_ENABLE                               True(1)
        SILENT_MODE                                 False(0)
        MKEY_BY_NAME_RANGE                          DEVICE_DEFAULT(0)
        ROCE_CONTROL                                ROCE_ENABLE(2)
        PCI_WR_ORDERING                             per_mkey(0)
        MULTI_PORT_VHCA_EN                          False(0)
        PF_TOTAL_SF                                 0
        PF_SD_GROUP                                 0
        PF_DEVICE_ID_ENABLE                         False(0)
        PF_SF_BAR_SIZE                              0
        PF_NUM_PF_MSIX                              63
        PF_DEVICE_ID                                41692
        BOOT_VLAN                                   1
        LEGACY_BOOT_PROTOCOL                        PXE(1)
        BOOT_INTERRUPT_DIS                          False(0)
        BOOT_LACP_DIS                               True(1)
        BOOT_VLAN_EN                                False(0)
        IP_VER                                      IPv4(0)
        BOOT_UNDI_NETWORK_WAIT                      0
        BOOT_DBG_LOG                                False(0)
        BOOT_PKEY                                   0
        UEFI_HII_EN                                 True(1)
        UEFI_LOGS                                   DISABLED(0)
        BAR_PAGE_ALIGNMENT                          DEVICE_DEFAULT(0)
        MANAGEMENT_PF_MODE                          DEVICE_DEFAULT(0)
        P2P_ORDERING_MODE                           DEVICE_DEFAULT(0)
        EXP_ROM_VIRTIO_NET_PXE_ENABLE               False(0)
        EXP_ROM_VIRTIO_NET_UEFI_ARM_ENABLE          False(0)
        EXP_ROM_VIRTIO_NET_UEFI_x86_ENABLE          False(0)
        EXP_ROM_VIRTIO_BLK_UEFI_ARM_ENABLE          False(0)
        EXP_ROM_VIRTIO_BLK_UEFI_x86_ENABLE          False(0)
        EXP_ROM_NVME_UEFI_x86_ENABLE                True(1)
        ATS_ENABLED                                 False(0)
        DYNAMIC_VF_MSIX_TABLE                       False(0)
        EXP_ROM_UEFI_ARM_ENABLE                     True(1)
        EXP_ROM_UEFI_x86_ENABLE                     True(1)
        EXP_ROM_PXE_ENABLE                          True(1)
        ADVANCED_PCI_SETTINGS                       False(0)
        SAFE_MODE_THRESHOLD                         10
        SAFE_MODE_ENABLE                            True(1)
The 'RO' shows parameters which are for read only and cannot be changed
  • devlink
ubuntu@localhost:~$ devlink port
pci/0000:03:00.0/262143: type eth netdev p0 flavour physical port 0 splittable false
  function:
    hw_addr 00:00:00:00:00:00 state inactive opstate detached
pci/0000:03:00.0/196608: type eth netdev pf0hpf flavour pcipf controller 1 pfnum 0 external true splittable false
  function:
    hw_addr a0:88:c2:81:aa:d4 state inactive opstate detached
pci/0000:03:00.0/229408: type eth netdev en3f0pf0sf0 flavour pcisf controller 0 pfnum 0 sfnum 0 splittable false
  function:
    hw_addr 02:d4:65:37:a1:19 state active opstate attached
pci/0000:03:00.1/327679: type eth netdev p1 flavour physical port 1 splittable false
  function:
pci/0000:03:00.1/262144: type eth netdev pf1hpf flavour pcipf controller 1 pfnum 1 external true splittable false
  function:
    hw_addr a0:88:c2:81:aa:d5 state inactive opstate detached
pci/0000:03:00.1/294944: type eth netdev en3f1pf1sf0 flavour pcisf controller 0 pfnum 1 sfnum 0 splittable false
  function:
    hw_addr 02:c8:1d:8a:9d:ca state active opstate attached
auxiliary/mlx5_core.sf.2/6619136: type eth netdev enp3s0f0s0 flavour virtual splittable false
auxiliary/mlx5_core.sf.3/8716288: type eth netdev enp3s0f1s0 flavour virtual splittable false
I’m happy to provide any additional information, logs, or configuration details that might help diagnose this issue.
Thank you.
Based on the documentation link you are using, it is a very old DOCA version (DOCA 2.5.2).
We recommend to use the latest DOCA, and check if the issue is reproduced.
Best Regards,
Anatoly
Hi user8937
I’m trying to compile that example, but it didn’t work. Could you please provide me with the steps you took to compile it?
Works ok with DOCA 3.1
root@dpu:/tmp/build/eth_l2_fwd# sudo ./doca_eth_l2_fwd -d mlx5_0,mlx5_1 -o 1
[10:23:33:168867][3170287648][DOCA][INF][doca_log.cpp:628] DOCA version 3.1.0105
[10:23:33:184603][3170287648][DOCA][WRN][doca_mmap.cpp:2015] Mmap 0xaaaaee25ac40: Memory range isn’t aligned to 64B - addr=0xffffb6afb010. For best performance using CPU memory, align address to 64B (cache-line size). For best performance using GPU memory, align address to 64KB (page size)
[10:23:33:193010][3170287648][DOCA][WRN][engine_model.c:88] adapting queue depth to 128.
EAL: Detected CPU lcores: 8
EAL: Multi-process socket /var/run/dpdk/1470604/mp_socket
EAL: Selected IOVA mode ‘PA’
[10:23:33:342303][3170287648][DOCA][WRN][hws_port.c:1165] ARGUMENT_256B resource doens’t exist, skip creating NAT64 actions
[10:23:33:440814][3170287648][DOCA][INF][eth_rxq_common.c:227][create_root_pipe] Created Pipe ROOT_PIPE
[10:23:33:440895][3170287648][DOCA][INF][eth_l2_fwd_core.c:722][forward_pkts] Starting packets forwarding
^C[10:23:37:114149][3170287648][DOCA][INF][eth_l2_fwd.c:48][signal_handler] Signal 2 received, preparing to exit
[10:23:37:114258][3170287648][DOCA][INF][eth_l2_fwd_core.c:184][eth_l2_fwd_show_stats]
**************************** Forward statistics for device 1 *****************************
RX-packets: 0 RX-SW-dropped: 0 RX-total: 0
TX-packets: 0
Throughput (since last call)
RX-pps: 0
TX-pps: 0
**************************** Forward statistics for device 2 *****************************
TX-packets: 0
RX-pps: 0
TX-pps: 0
[10:23:37:114286][3170287648][DOCA][INF][eth_l2_fwd_core.c:735][forward_pkts] Finished packets forwarding
[10:23:37:114320][3170287648][DOCA][INF][eth_l2_fwd_core.c:887][eth_l2_fwd_execute] Ethernet L2 Forwarding Application execution finished successfully
[10:23:37:550459][3170287648][DOCA][INF][eth_l2_fwd_core.c:1109][eth_l2_fwd_cleanup] Ethernet L2 Forwarding Application resources cleanup finished successfully
Hi abriman and tuanama00,
I appreciate your feedback and that you gave it a try.
I was able to confirm that it works after upgrading the DOCA version on my end as well.
I have one question: I read that the DOCA Eth library can only handle SFs in a DPU environment. Is this limitation not present in DOCA 3.1.0?
ref: DOCA Eth L2 Forwarding Application Guide - NVIDIA Docs
Best Regards,
Shunsuke
