DOCA Flow Match Not Working on BlueField2
I’m currently working with a DOCA Flow program on a BlueField2 DPU, using DOCA SDK version 2.8.0081, I am trying to filter TCP packets based on destination port, but the match rule does not seem to work.
Environment:
  • DOCA SDK Version: 2.8.0081
  • Open vSwitch (OVS) Version: 2.8.0-0091-24.07-based-3.3.0
  • DPU Model: BlueField2
  • OVS Configuration:
Bridge ovsbr2
    Port ovsbr2
        Interface ovsbr2
            type: internal
    Port p1
        Interface p1
    Port en3f1pf1sf0
        Interface en3f1pf1sf0
    Port pf1hpf
        Interface pf1hpf
Bridge ovsbr1
    Port ovsbr1
        Interface ovsbr1
            type: internal
    Port en3f0pf0sf88
        Interface en3f0pf0sf88
    Port p0
        Interface p0
    Port pf0hpf
        Interface pf0hpf
    Port en3f0pf0sf0
        Interface en3f0pf0sf0
I have set up a port mirror to capture traffic from port pf0hpf and mirror it to en3f0pf0sf88:
ovs-vsctl -- --id=@p1 get port en3f0pf0sf88 \
            -- --id=@p2 get port pf0hpf \
            -- --id=@m create mirror name=m0 select-dst-port=@p2 output-port=@p1 \
            -- set bridge ovsbr2 mirrors=@m
Code
I am trying to filter packets based on TCP destination port from sf88 and forward them to RSS for processing. My flow match is defined as follows in the code:
static doca_error_t create_rss_pipe(struct doca_flow_port *port, struct doca_flow_pipe **pipe)
    struct doca_flow_match match;
    struct doca_flow_actions actions, *actions_arr[NB_ACTIONS_ARR];
    struct doca_flow_fwd fwd;
    struct doca_flow_fwd fwd_miss;
    struct doca_flow_pipe_cfg *pipe_cfg;
    uint16_t rss_queues[1];
    doca_error_t result;
    memset(&match, 0, sizeof(match));
    memset(&actions, 0, sizeof(actions));
    memset(&fwd, 0, sizeof(fwd));
    memset(&fwd_miss, 0, sizeof(fwd_miss));
    actions_arr[0] = &actions;
    /* 5-tuple match */
    match.parser_meta.outer_l4_type = DOCA_FLOW_L4_META_TCP;
    match.parser_meta.outer_l3_type = DOCA_FLOW_L3_META_IPV4;
    match.outer.l4_type_ext = DOCA_FLOW_L4_TYPE_EXT_TCP;
    match.outer.l3_type = DOCA_FLOW_L3_TYPE_IP4;
    match.outer.ip4.src_ip = 0xffffffff;
    match.outer.ip4.dst_ip = 0xffffffff;
    match.outer.tcp.l4_port.src_port = 0xffff;
    match.outer.tcp.l4_port.dst_port = 0xffff;
    result = doca_flow_pipe_cfg_create(&pipe_cfg, port);
    if (result != DOCA_SUCCESS) {
        DOCA_LOG_ERR("Failed to create doca_flow_pipe_cfg: %s", doca_error_get_descr(result));
        return result;
    result = set_flow_pipe_cfg(pipe_cfg, "RSS_META_PIPE", DOCA_FLOW_PIPE_BASIC, true);
        DOCA_LOG_ERR("Failed to set doca_flow_pipe_cfg: %s", doca_error_get_descr(result));
        goto destroy_pipe_cfg;
    result = doca_flow_pipe_cfg_set_match(pipe_cfg, &match, NULL);
        DOCA_LOG_ERR("Failed to set doca_flow_pipe_cfg match: %s", doca_error_get_descr(result));
    result = doca_flow_pipe_cfg_set_actions(pipe_cfg, actions_arr, NULL, NULL, NB_ACTIONS_ARR);
        DOCA_LOG_ERR("Failed to set doca_flow_pipe_cfg actions: %s", doca_error_get_descr(result));
    /* RSS queue - send matched traffic to queue 0  */
    rss_queues[0] = 0;
    fwd.type = DOCA_FLOW_FWD_RSS;
    fwd.rss_queues = rss_queues;
    fwd.rss_inner_flags = DOCA_FLOW_RSS_IPV4 | DOCA_FLOW_RSS_TCP;
    fwd.num_of_queues = 1;
    fwd_miss.type = DOCA_FLOW_FWD_DROP;
    result = doca_flow_pipe_create(pipe_cfg, &fwd, &fwd_miss, pipe);
destroy_pipe_cfg:
    doca_flow_pipe_cfg_destroy(pipe_cfg);
    return result;
And the flow entry is defined as:
static doca_error_t add_rss_pipe_entry(struct doca_flow_pipe *pipe, struct entries_status *status)
    DOCA_LOG_INFO("Start add entry...");
    struct doca_flow_actions actions;
    struct doca_flow_pipe_entry *entry;
    /* example 5-tuple to drop */
    doca_be32_t dst_ip_addr = BE_IPV4_ADDR(192, 168, 200, 2);
    doca_be32_t src_ip_addr = BE_IPV4_ADDR(192, 168, 200, 1);
    doca_be16_t dst_port = rte_cpu_to_be_16(8082);
    doca_be16_t src_port = rte_cpu_to_be_16(1234);
    match.outer.ip4.dst_ip = dst_ip_addr;
    match.outer.ip4.src_ip = src_ip_addr;
    match.outer.tcp.l4_port.dst_port = dst_port;
    match.outer.tcp.l4_port.src_port = src_port;
    result = doca_flow_pipe_add_entry(0, pipe, &match, &actions, NULL, NULL, 0, status, &entry);
    DOCA_LOG_INFO("Matching IP: src=%x, dst=%x, dst_port=%u", src_ip_addr, dst_ip_addr, dst_port);
        return result;
    return DOCA_SUCCESS;
doca_error_t flow_rss(int nb_queues)
	const int nb_ports = 1;
	struct flow_resources resource = {0};
	uint32_t nr_shared_resources[SHARED_RESOURCE_NUM_VALUES] = {0};
	struct doca_flow_port *ports[nb_ports];
	struct doca_dev *dev_arr[nb_ports];
	struct doca_flow_pipe *pipe;
	struct entries_status status;
	int num_of_entries = 1;
	int port_id;
	result = init_doca_flow(nb_queues, "vnf,hws", &resource, nr_shared_resources);
	// result = init_doca_flow(nb_queues, "vnf,hws", &resource, nr_shared_resources);
		DOCA_LOG_ERR("Failed to init DOCA Flow: %s", doca_error_get_descr(result));
		return -1;
	memset(dev_arr, 0, sizeof(struct doca_dev *) * nb_ports);
	result = init_doca_flow_ports(nb_ports, ports, true, dev_arr);
		DOCA_LOG_ERR("Failed to init DOCA ports: %s", doca_error_get_descr(result));
		doca_flow_destroy();
		return result;
	for (port_id = 0; port_id < nb_ports; port_id++) {
		memset(&status, 0, sizeof(status));
		result = create_rss_pipe(ports[port_id], &pipe);
			DOCA_LOG_ERR("Failed to create pipe: %s", doca_error_get_descr(result));
			stop_doca_flow_ports(nb_ports, ports);
			return result;
		result = add_rss_pipe_entry(pipe, &status);
			DOCA_LOG_ERR("Failed to add entry: %s", doca_error_get_descr(result));
			return result;
		result = doca_flow_entries_process(ports[port_id], 0, DEFAULT_TIMEOUT_US, num_of_entries);
			DOCA_LOG_ERR("Failed to process entries: %s", doca_error_get_descr(result));
			return result;
		if (status.nb_processed != num_of_entries || status.failure) {
			DOCA_LOG_ERR("Failed to process entries");
			return DOCA_ERROR_BAD_STATE;
	DOCA_LOG_INFO("Wait few seconds for packets to arrive");
	sleep(1);
		process_packets(port_id);
	result = stop_doca_flow_ports(nb_ports, ports);
	return result;
The Issue:
The match rule does not seem to work properly, and after calling the flow_rss function, all packets received on sf88 are forwarded to the RSS, regardless of whether they match the filter.
Question:
I’m currently using VNF mode for the pipe, but I’m wondering if pipe mode could be the cause of the issue? Since I’m running OVS, would using switch mode be necessary for the flow match to work properly?
Has anyone encountered a similar issue or could provide some insights on this?
Thanks in advance!
Hi @dufanrong ,
In the create_rss_pipe function, you’re setting all match fields to 0xFFFFFFFF or 0xFFFF, which essentially means you’re matching everything. Specifically:
This configuration matches all TCP packets, which is why all packets are being forwarded to RSS. Try setting the destination port field to the relevant port that the rule should match.
Thanks,
Chen
Thank you for your reply. I understand what you mean about needing to set match.outer.tcp.l4_port.dst_port to the port I need in the create_rss_pipe function, but there is a mention in the doc DOCA Flow - NVIDIA Docs that you can use the Changeable type, which is set in create_rss_pipe to 0xffff and then set it to the specific value in the add_rss_pipe_entry function. I did in fact do this, in my add_rss_pipe_entry function I set
but still received all the packets at rss.
I set
match.outer.tcp.l4_port.dst_port = rte_cpu_to_be_16(8082);
in my create_rss_pipe function as you mentioned, but it still doesn’t work, I want to forward the packets with dst_port=8082 to rss, the output after running the code is
../build/doca_flow_rss_meta -a auxiliary:mlx5_core.sf.4,dv_flow_en=2 -- -l 70
[04:15:19:038622][1485278][DOCA][INF][flow_rss_meta_main.c:69][main] Starting the sample
EAL: Detected CPU lcores: 8
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
TELEMETRY: No legacy callbacks, legacy socket not created
[04:15:20:639688][1485278][DOCA][DBG][dpdk_utils.c:418][port_init] Port 0 MAC: 00 00 00 00 88 88
[04:15:20:641030][1485278][DOCA][WRN][engine_model.c:90][adapt_queue_depth] adapting queue depth to 128.
[04:15:22:470375][1485278][DOCA][INF][flow_rss_meta_sample.c:267][add_rss_pipe_entry] Start add entry...
[04:15:22:470480][1485278][DOCA][INF][flow_rss_meta_sample.c:366][flow_rss] Wait few seconds for packets to arrive
[04:15:23:470630][1485278][DOCA][INF][flow_rss_meta_sample.c:151][process_packets] Port 0: Received 39 packets
[04:15:23:470694][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470707][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470724][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470737][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470747][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470761][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470772][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470784][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470795][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470807][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470818][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470830][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470841][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470851][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470860][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470870][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470881][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470892][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470902][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470912][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470923][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470945][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470957][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470968][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:470979][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:470989][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471000][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471011][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471022][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471034][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471045][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471054][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471065][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471076][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471088][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471100][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471109][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471121][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471131][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471142][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471153][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471163][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471174][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471186][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471195][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471207][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471218][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471230][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471241][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471251][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471262][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471271][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471284][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471296][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471306][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471318][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471328][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471338][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471350][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471359][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471372][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471385][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471396][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471408][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471418][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471430][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471440][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471452][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471463][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471475][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471486][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471498][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471509][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471520][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471533][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471550][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:471561][1485278][DOCA][DBG][flow_rss_meta_sample.c:55][print_ipv4_addr] DIP=192.168.200.2, SIP=192.168.200.1, L4_TCP
[04:15:23:471574][1485278][DOCA][DBG][flow_rss_meta_sample.c:173][process_packets] TCP- DPORT 8081, SPORT 58584
[04:15:23:790544][1485278][DOCA][DBG][dpdk_utils.c:927][dpdk_fini] DPDK fini is done
[04:15:23:790605][1485278][DOCA][INF][flow_rss_meta_main.c:107][main] Sample finished successfully
The program still forwards the packet with dst_port 8081 to rss. i don’t know what is the reason for this, do you have any insight?
