Hello folks,
Can anyone add information about the difference between DOCA_FLOW_PIPE_CONTROL and DOCA_FLOW_PIPE_ACL?
Is there a performance difference or nb flow per pipe?
What I’ve found now it is the difference regarding the ports range functionality.
11.3.11 (Flow Programming Guide - NVIDIA Docs)
For ACL pipe it should work as:
Mask port is 0 ==> Any port
Mask port is equal to match port ==> Exact port. Port with mask 0xffff.
Mask port > match port ==> Match port is used as port from and mask port is used as port to
I dont check it yet.
But for CONTROL pipe it works as:
Mask port > match port ==> 0 is used as port from and mask port is used as port to
Is it undefined behaviour?
doca 2.0.2 version
Thanks in advance
