There is a problem when I try to run the GPU Packet Processing example in DOCA 2.0.
The topology is attached, I use a server with 2 NICs connected through an external cable.
When I tried to run :
sudo ./doca_gpu_packet_processing -g b1:00.0 -n 31:00.1 -q 2 in terminal 1(the pcie address is where the NIC port ens786f1np1, assigned IP 192.168.202.10 locates)
and ping the 192.168.202.10 from another NIC’s port ens785f0, 192.168.202.20.
The result indicates the DOCA does not pass the ICMP message to GPU.
Can anyone help?
Thanks a lot.
