I’m currently trying to set up DOCA NVMe Emulation on a BlueField DPU , but I keep running into an issue where the Emulation Manager never appears. When I attempt to run command (sudo PYTHONPATH=/opt/mellanox/doca/applications/nvme_emulation /usr/bin/spdk_rpc.py --plugin rpc_nvmf_doca nvmf_doca_get_managers), it returns an empty list ( )
I’ve solved the issue. Below is a script for anyone who might run into the same difficulties later.
Note: You must switch the BlueField device to DPU mode.
sudo mlxconfig -d /dev/mst/mt41692_pciconf0 s INTERNAL_CPU_MODEL=1
sudo mlxconfig -d /dev/mst/mt41692_pciconf0 s INTERNAL_CPU_OFFLOAD_ENGINE=0
sudo PYTHONPATH=/opt/mellanox/doca/applications/nvme_emulation /usr/bin/spdk_rpc.py --plugin rpc_nvmf_doca nvmf_doca_create_function -d mlx5_0
sudo PYTHONPATH=/opt/mellanox/doca/applications/nvme_emulation /usr/bin/spdk_rpc.py nvmf_create_transport -t doca -u 8192 -i 131072 -c 819
sudo scripts/rpc.py bdev_malloc_create -b malloc0 64 512
sudo /usr/bin/spdk_rpc.py bdev_malloc_create -b malloc0 64 512
sudo /usr/bin/spdk_rpc.py nvmf_create_subsystem nqn.2016-06.io.spdk:cnode1 -a
sudo /usr/bin/spdk_rpc.py nvmf_subsystem_add_ns nqn.2016-06.io.spdk:cnode1 malloc0
sudo PYTHONPATH=/opt/mellanox/doca/applications/nvme_emulation /usr/bin/spdk_rpc.py --plugin rpc_nvmf_doca nvmf_subsystem_add_listener nqn.2016-06.io.spdk:cnode1 -t doca -a MT2427XZ0ZNWGES1D0F0
With these commands, BlueField will be in DPU mode and DOCA NVMe emulation should work properly.
Thank you
