【DOCA】【OFED】ConnectX-7 rate limit failed error
I use mlnx_qos tool set connectx-7 rdma nic rate limit meet error as below:
$ sudo mlnx_qos -i ens25np0 -r 0,0,0,0,0,350,0,0
Rate limit is not supported on your system!
DCBX mode: OS controlled
Priority trust state: pcp
Receive buffer size (bytes): 0,1046016,0,0,0,0,0,0,max_buffer_size=4148640
Cable len: 7
PFC configuration:
        priority    0   1   2   3   4   5   6   7
        enabled     0   0   0   0   0   0   0   0
        buffer      1   1   1   1   1   1   1   1
tc: 0 ratelimit: unlimited, tsa: vendor
         priority:  1
tc: 1 ratelimit: unlimited, tsa: vendor
         priority:  0
tc: 2 ratelimit: unlimited, tsa: vendor
         priority:  2
tc: 3 ratelimit: unlimited, tsa: vendor
         priority:  3
tc: 4 ratelimit: unlimited, tsa: vendor
         priority:  4
tc: 5 ratelimit: 50.0 Gbps, tsa: vendor
         priority:  5
tc: 6 ratelimit: unlimited, tsa: vendor
         priority:  6
tc: 7 ratelimit: unlimited, tsa: vendor
         priority:  7
error msg :Rate limit is not supported on your system!
dmesg error msg: mlx5_core 0000:53:00.0 ens25np0: tc_5 maxrate 300000000 Kbps exceeds limit 255000000
more detail log: ConnectX-7-log.txt (15.9 KB)
hardware info:
Device type:        ConnectX7
Description:        NVIDIA ConnectX-7 HHHL Adapter card; 400GbE / NDR IB (default mode); Single-port OSFP; PCIe 5.0 x16; Crypto Disabled; Secure Boot Enabled;
Device:             13:00.0
From kernel source code , I found that qetcr_qshr_max_bw_val_msb capability bit not enable.
static ssize_t mlx5e_store_maxrate(struct device *device,
                                   struct device_attribute *attr,
                                   const char *buf, size_t count)
        struct mlx5e_priv *priv = netdev_priv(to_net_dev(device));
        struct mlx5_core_dev *mdev = priv->mdev;
        u64 tc_maxrate[IEEE_8021QAZ_MAX_TCS];
        u16 max_bw_value[MLX5_MAX_NUM_TC];
        u8 max_bw_unit[MLX5_MAX_NUM_TC];
        u64 upper_limit_100mbps;
        u64 upper_limit_gbps;
        char delimiter;
        u16 type_max;
        int i = 0;
        int ret;
        memset(max_bw_value, 0, sizeof(max_bw_value));
        memset(max_bw_unit, 0, sizeof(max_bw_unit));
        type_max = MLX5_CAP_QCAM_FEATURE(mdev, qetcr_qshr_max_bw_val_msb) ?
                   U16_MAX : U8_MAX;
        upper_limit_100mbps = type_max * MLX5E_100MB_TO_KB;
        upper_limit_gbps = type_max * MLX5E_1GB_TO_KB;
        do {
                int len;
                u64 input_maxrate;
                if (i >= MLX5_MAX_NUM_TC)
                        goto bad_elem_count;
                len = strcspn(buf, " ");
                /* nul-terminate and parse */
                delimiter = buf[len];
                ((char *)buf)[len] = '\0';
                if (sscanf(buf, "%lld", &input_maxrate) != 1
                           || input_maxrate < 0) {
                        netdev_err(priv->netdev, "bad maxrate value: '%s'\n",
                                   buf);
                        goto out;
                tc_maxrate[i] = input_maxrate;
                buf += len + 1;
                i++;
        } while (delimiter == ' ');
        if (i != MLX5_MAX_NUM_TC)
        for (i = 0; i < IEEE_8021QAZ_MAX_TCS; i++) {
                u64 rate = tc_maxrate[i];
                if (!tc_maxrate[i]) {
                        max_bw_unit[i]  = MLX5_BW_NO_LIMIT;
                        continue;
                if (rate <= upper_limit_100mbps) {
                        max_bw_value[i] = div_u64(rate, MLX5E_100MB_TO_KB);
                        max_bw_value[i] = max_bw_value[i] ? max_bw_value[i] : 1;
                        max_bw_unit[i]  = MLX5_100_MBPS_UNIT;
                } else if (rate <= upper_limit_gbps) {
                        max_bw_value[i] = div_u64(rate, MLX5E_1GB_TO_KB);
                        max_bw_unit[i]  = MLX5_GBPS_UNIT;
                } else {
                                   "tc_%d maxrate %llu Kbps exceeds limit %llu\n",
                                   i, rate, upper_limit_gbps);
                        return -EINVAL;
reference link : net/mlx5: Add IFC bits for extended ETS rate limit bandwidth value | Patchew
I think doca-ofed [OFED-internal-26.04-0.8.6] for connectx-7 rnic should support rate limit function.
@spruitt Can you help me to figure out why qetcr_qshr_max_bw_val_msb bit not enable.
Did I need do more configure for ConnectX-7 rnic ?
I have found the root cause , because after update doca-ofed and firmware , I didn’t reboot with power off to make sure switch to new firmware.
After reboot , mlnx_qos rate limit take effect.
