How does DOCA PDA recognize the received custom message to trigger an event to implementing a new CC algorithm?
Thanks for your question.
To answer it we will need much more context and details about the scenario you are using.
i.e. software and hardware versions, application and/or compilation logs (errors), and configurations.
In order to check all the mentioned information, we would ask you to open a new support case in Nvidia portal, and it will be handled according to the entitlement.
To Create a New Enterprise Support Case Please Use One of the Following Methods
Log in and Create a Case in the Enterprise Support Portal
AppHub UI
This is recommended and will provide the fastest response -
Call your Regional Enterprise Support Number
Find your regional phone numbers:
NVIDIA Enterprise Customer Support -
Create a Case Without a Login
EnterpriseSupport
Can be used to check warranty status
Recommended to reset login passwords
Requires validation and may increase time to respond
Best Regards,
Anatoly
