Hi ,
I had installed the BF2 in my server , had flashed the binary using the GUI method , unfortunately facing the below error when application is ran , looks like doca-common package is missing , kindly do let me know , how to fix the same
root@localhost:/opt/mellanox/doca/samples/doca_dma/dma_local_copy# meson build
The Meson build system
Version: 0.61.2
Source dir: /opt/mellanox/doca/samples/doca_dma/dma_local_copy
Build dir: /opt/mellanox/doca/samples/doca_dma/dma_local_copy/build
Build type: native build
Program cat found: YES (/usr/bin/cat)
Project name: DOCA_SAMPLE
Project version: 1.5.1007
C compiler for the host machine: cc (gcc 9.4.0 “cc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0”)
C linker for the host machine: cc ld.bfd 2.34
C++ compiler for the host machine: c++ (gcc 9.4.0 “c++ (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0”)
C++ linker for the host machine: c++ ld.bfd 2.34
Host machine cpu family: aarch64
Host machine cpu: aarch64
Found pkg-config: /usr/bin/pkg-config (0.29.1)
Did not find CMake ‘cmake’
Found CMake: NO
Run-time dependency doca-common found: NO (tried pkgconfig)
meson.build:29:0: ERROR: Dependency “doca-common” not found, tried pkgconfig
A full log can be found at /opt/mellanox/doca/samples/doca_dma/dma_local_copy/build/meson-logs/meson-log.txt
