Docker Build Error: Cannot find -lnvbufsurface and -lnvbufsurftransform
I encountered an error when trying to build a Docker image using a docker buildx (BuildKit). The error appears to be related to missing libraries, specifically -lnvbufsurface and -lnvbufsurftransform.
Dockerfile:
FROM nvcr.io/nvidia/deepstream-l4t:6.2-triton
ENV CUDA_VER=11.4
WORKDIR /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-image-meta-test
RUN make && make install
Build command:
docker buildx build --platform linux/arm64 --file Dockerfile .
Error message:
 > [3/3] RUN make && make install:
#0 1.026 cc -c -o deepstream_image_meta_test.o -DPLATFORM_TEGRA -I../../../includes -I /usr/local/cuda-11.4/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/aarch64-linux-gnu/glib-2.0/include deepstream_image_meta_test.c
#0 2.947 cc -o deepstream-image-meta-test deepstream_image_meta_test.o -lgstreamer-1.0 -lgobject-2.0 -lglib-2.0 -L/opt/nvidia/deepstream/deepstream-6.2/lib/ -lnvdsgst_meta -lnvds_meta -lnvbufsurface -lnvbufsurftransform -lnvdsgst_helper -lnvds_batch_jpegenc -L/usr/local/cuda-11.4/lib64/ -lcudart -lm -lcuda -Wl,-rpath,/opt/nvidia/deepstream/deepstream-6.2/lib/
#0 3.165 /usr/bin/ld: cannot find -lnvbufsurface
#0 3.165 /usr/bin/ld: cannot find -lnvbufsurftransform
#0 3.171 collect2: error: ld returned 1 exit status
#0 3.180 make: *** [Makefile:68: deepstream-image-meta-test] Error 1
docker buildx version: buildx v0.10.4 c513d34
I am run it on linux/amd64 machine.
can you find libnvbufsurface.so and libnvbufsurftransform.so in the path /opt/nvidia/deepstream/deepstream-6.2/lib/ .
Yes. I can see it here.
could you share the output of ll /opt/nvidia/deepstream/deepstream-6.2/lib/libnvbufsurftransform.so?
I have this output:
lrwxrwxrwx 1 root root 57 Jan 31 23:55 /opt/nvidia/deepstream/deepstream-6.2/lib/libnvbufsurftransform.so -> /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so
But when I made ls -ll /usr/lib/aarch64-linux-gnu/tegra/ I had error ls: cannot access '/usr/lib/aarch64-linux-gnu/tegra/': No such file or directory. I guess it because buildx.
please refer to building docker sample:Docker Containers — DeepStream 6.2 Release documentation
