I’ve created a docker build file (myDockerfile.isaac) for building a container for Jetson Orin Nano development board. The build is close to completing, but fails duing build of isaac_ros_nitros
It fails with a type conflict between what appears to be a cuda declaration, and a previous declaration:
/usr/local/cuda/include/cuda/std/detail/libcxx/include/cmath:572:101: error: ‘long double cuda::std::__3::hypot(long double, long double, long double)’ conflicts with a previous declaration
572 | inline _LIBCUDACXX_INLINE_VISIBILITY long double hypot( long double x, long double y, long double z ) { return sqrt(xx + yy + z*z); }
Any input would be greatly appreciated
BobA
— Here is a snipped from the build failure:
Starting >>> isaac_ros_nitros
Finished <<< isaac_ros_pointcloud_interfaces [25.1s]
Finished <<< isaac_ros_apriltag_interfaces [27.5s]
Finished <<< isaac_ros_tensor_list_interfaces [28.2s]
Finished <<< isaac_ros_bi3d_interfaces [26.6s]
Finished <<< isaac_ros_visual_slam_interfaces [48.8s]
— stderr: isaac_ros_nitros
In file included from /usr/local/cuda/include/cuda/std/cmath:19,
from /usr/local/cuda/include/cuda/std/complex:12,
from /opt/isaac_ros_ws/install/share/isaac_ros_gxf/gxf/include/gxf/std/complex.hpp:23,
from /opt/isaac_ros_ws/install/share/isaac_ros_gxf/gxf/include/gxf/std/tensor.hpp:30,
from /opt/isaac_ros_ws/install/share/isaac_ros_gxf/gxf/include/gxf/multimedia/video.hpp:30,
from /opt/isaac_ros_ws/src/isaac_ros_nitros/isaac_ros_nitros/include/isaac_ros_nitros/utils/vpi_utilities.hpp:20,
from /opt/isaac_ros_ws/src/isaac_ros_nitros/isaac_ros_nitros/src/utils/vpi_utilities.cpp:11:
/usr/local/cuda/include/cuda/std/detail/libcxx/include/cmath:569:101: error: ‘float cuda::std::__3::hypot(float, float, float)’ conflicts with a previous declaration
569 | inline _LIBCUDACXX_INLINE_VISIBILITY float hypot( float x, float y, float z ) { return sqrt(xx + yy + zz); }
In file included from /opt/isaac_ros_ws/build/isaac_ros_nitros/_deps/yaml-cpp-src/include/yaml-cpp/emitter.h:10,
from /opt/isaac_ros_ws/build/isaac_ros_nitros/_deps/yaml-cpp-src/include/yaml-cpp/yaml.h:11,
from /opt/isaac_ros_ws/install/share/isaac_ros_gxf/gxf/include/gxf/std/parameter_parser.hpp:31,
from /opt/isaac_ros_ws/install/share/isaac_ros_gxf/gxf/include/gxf/core/parameter.hpp:29,
from /opt/isaac_ros_ws/install/share/isaac_ros_gxf/gxf/include/gxf/core/component.hpp:25,
from /opt/isaac_ros_ws/install/share/isaac_ros_gxf/gxf/include/gxf/std/allocator.hpp:21,
from /opt/isaac_ros_ws/install/share/isaac_ros_gxf/gxf/include/gxf/multimedia/video.hpp:28,
from /opt/isaac_ros_ws/src/isaac_ros_nitros/isaac_ros_nitros/include/isaac_ros_nitros/utils/vpi_utilities.hpp:20,**
/usr/include/c++/9/cmath:1868:3: note: previous declaration ‘float std::hypot(float, float, float)’
1868 | hypot(float __x, float __y, float __z)
/usr/local/cuda/include/cuda/std/detail/libcxx/include/cmath:570:101: error: ‘double cuda::std::__3::hypot(double, double, double)’ conflicts with a previous declaration**
570 | inline _LIBCUDACXX_INLINE_VISIBILITY double hypot( double x, double y, double z ) { return sqrt(xx + yy + zz); }
/usr/include/c++/9/cmath:1872:3: note: previous declaration ‘double std::hypot(double, double, double)’
1872 | hypot(double __x, double __y, double __z)
/usr/include/c++/9/cmath:1876:3: note: previous declaration ‘long double std::hypot(long double, long double, long double)’
1876 | hypot(long double __x, long double __y, long double __z)
make[2]: [CMakeFiles/isaac_ros_nitros.dir/build.make:188: CMakeFiles/isaac_ros_nitros.dir/src/utils/vpi_utilities.cpp.o] Error 1
make[2]: Waiting for unfinished jobs…
make[1]: [CMakeFiles/Makefile2:159: CMakeFiles/isaac_ros_nitros.dir/all] Error 2
**make: *** [Makefile:146: all] Error 2
Failed <<< isaac_ros_nitros [1min 16s, exited with code 2]
[Processing: isaac_ros_nitros]
Summary: 9 packages finished [1min 53s]
1 package failed: isaac_ros_nitros
