hello nv team!
i can’t run the sample camera_v4l2_cuda of the tegra_multimedia_api in vitual docker container.
it showed this error below
nvidia@4018b7faca4a~/jetpack3.2/tegra_multimedia_api/samples/12_camera_v4l2_cuda $ ./camera_v4l2_cuda -d /dev/video0 -s 640x480 -f YUYV -n 30 -c
Error: Can't initialize nvrm channel
Couldn't create ddkvic Session: Cannot allocate memory
WARN: camera_initialize(): (line:239) The desired format is not supported
[INFO] (NvEglRenderer.cpp:109) <renderer0> Setting Screen width 1920 height 1080
[ERROR] (NvEglRenderer.cpp:204) <renderer0> Unable to initialize egl library
[ERROR] (NvEglRenderer.cpp:152) <renderer0> Got ERROR closing display
ERROR: display_initialize(): (line:261) Failed to create EGL renderer
ERROR: init_components(): (line:286) Failed to initialize display
ERROR: main(): (line:530) Failed to initialize v4l2 components
nvbuf_utils: dmabuf_fd 0 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
App run failed
this is my jetson tx2 environment
[envirionment]
Jetson TX2 R28.2.1
Docker version 1.13.1
[docker run argument]
docker run -v /mnt/log:/mnt/log:rw \
-v /dev:/dev:rw \
--device=/dev/video0 \
--device=/dev/i2c-0 \
--device=/dev/nvhost-vic \
-e DISPLAY=$DISPLAY \
-v /tmp/.X11-unix:/tmp/.X11-unix \
-i -t test-rep/test-product:3b480b5ae6ee /bin/bash
it operates correctly in its real environment.
i don’t know what the nvrm it is??
i will wait your hint
previously thanks
