Docker-ce 28.0.0 won't run under current L4T
After updating L4T (using apt update && apt upgrade) earlier today, Docker failed to start. The update included an upgrade to docker-ce version 28.0.0. The specific error encountered during startup is:
failed to start daemon: Error initializing network controller: error obtaining controller instance: failed to register bridge" driver: invalid argument
I had to downgrade Docker back to version 27.5.1 (apt install docker-ce=5:27.5.1-1~ubuntu.22.04~jammy) to resume normal ops.
L4T:
> cat /proc/version
Linux version 5.15.148-tegra (buildbrain@mobile-u64-6336-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Tue Jan 7 17:14:38 PST 2025
> lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.5 LTS
Release:        22.04
Codename:       jammy
Please try to restart the docker service to see if it helps.
$ sudo systemctl restart docker.service
I have the same issue and restarting the service does not resolve the issue.
I’m on the same version
Linux version 5.15.148-tegra (root@avermedia.com) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon Oct 28 12:58:01 CST 2024
Release: 22.04
Codename: jammy
best regards
Restarting doesn’t help. The latest Docker update is not compatible with default config of the L4T network stack.
This issue is related: Please update check-config with new 28.0.0 ipset requirements · Issue #49503 · moby/moby · GitHub
New kernel modules/options are required for the latest Docker version to run.
Fix for now:
sudo apt-get install -y docker-ce=5:27.5.1-1~ubuntu.22.04~jammy --allow-downgrades
sudo apt-get install -y docker-ce-cli=5:27.5.1-1~ubuntu.22.04~jammy --allow-downgrades
To get info about previous versions of docker run:
apt-cache madison docker-ce
Indeed downgrading docker worked for me.
Same here, i was going crazy thinking I’m the problem, because I was unable to recreate flash I did 2 days ago.
thanks for posting bro !
Thanks for info worked for me as well
Cheers
sudo apt-mark hold docker-ce=5:27.5.1-1~ubuntu.22.04~jammy
sudo apt-mark hold docker-ce-cli=5:27.5.1-1~ubuntu.22.04~jammy
Downgrading worked. Also should make sure to turn off docker software updates until this issue is resolved.
Downgrading worked.
Thanks for posting!
Lost 2hrs, but could be more!!
Hi, all
Thanks for the update.
Another possible workaround is to build the kernel with the required config.
You can find more details in the below comment:
Thanks for posting.
I lost 2 days
