Docker-compose not working on Xavier AGX custom board
I’ve installed docker-compose on my custom Xavier AGX board using:
sudo pip3 install docker-compose
Installation finished successfully. But unfortunately the tool doesn’t work. Command:
docker-compose up
returns
Illlegal instruction (core dumped)
I have no idea how I could troubleshoot this issue. Could someone please provide a hint?
Could you try to set the following environment variable to see if it works?
$ export OPENBLAS_CORETYPE=ARMV8
I have already tried this but to no avail.
I finally got it to work. I had to format my nvme and do a fresh install. Then used following commands:
$ sudo apt update
$ sudo apt install python3-pip
$ sudo apt-get install -y libffi-dev
$ sudo apt-get install -y python-openssl
$ sudo apt-get install libssl-dev
$ sudo pip3 install docker-compose
