Docker compose takes a long time to create not finished
Hardware: Jetson AGX Orin.
Software:
Jetpack: Version: 6.0-b52
deepstream-app version 6.4.0
DeepStreamSDK 6.4.0
After following the Quick Start Guide — Metropolis on Jetson documentation 0.1.0 documentation When I run the following command
sudo docker compose -f compose_agx.yaml up -d --force-recreate
Docker compose takes a long time to create not finished.
can anyone help me with what is going wrong here?
Can you have a try with: Delayed startup of specific components like DeepStream and VST within the AI NVR setup - #6 by kesong
@kesong
Thanks for your response. I found that I was using compose_agx.yaml, which I got from the NCG application bundle for AI-NVR from NGC.
I downloaded the latest application bundle for MMJ and removed the old one.
Now things work.
