Docker: Error response from daemon: could not select device driver "" with capabilities: [[gpu]]
docker run --gpus all -it --name trt_test nvcr.io/nvidia/tensorrt:20.12-py3
docker: Error response from daemon: could not select device driver “” with capabilities: [[gpu]].
ERRO[0005] error waiting for container: context canceled
Can you tell me how to resolve this problem?
Thank you.
have you solved it ? I have the same error .
Did anyone resolved the issue, please do share the process.
Requesting Nvidia experts, kindly respond the queries pending.
Thanks and Regards,
Vyom Mishra
Resolved issue, In my case the repo was broken, but it could simply be nvidia-container-toolkit-base missing
Try:
sudo apt-get update
sudo apt-get install -y nvidia-container-toolkit
if its not able to install, repair your repository following instructions found here:
apt-get can’t find nvidia-container-toolkit-base #1731
