Docker error trying to run NGC container on Jetson Nano
I managed to run this container on an Xavier NX.
https://ngc.nvidia.com/catalog/containers/nvidia:l4t-ml
But when I try to run it on a Nano (created with a headless install using the latest image), I get this:
$ sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-ml:r32.4.2-py3
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "exec: \"/bin/sh\": stat /bin/sh: no such file or directory": unknown.
What can I do to resolve this?
We are going to check this issue.
Here is a related issue and you can check it first:
We can run the container on Nano with JetPack4.4 DP without issue.
A possible cause is the incompatibility of OS version.
Are you using JetPack4.4? If not, please reflash your system into rel-32.4.2 first.
