I have been using my Orin nano for a few weeks and keep hitting the same issue. I do a clean install to my NVMe driver using SDK Manager running on my home Ubuntu 22.04 machine. All works perfectly and I install pretty much everything as I have 500 GB.
Then I install jetson-inference and jetson-containers from the duty-nv github site. Both work perfectly and I am happily using inference plus cool tools like stable-diffusion,
but then I reboot. That’s it. No containers work anymore. If I run
sudo systemctl status docker
I get an error that says the has failed, no real information in the status other than docker.service: Failed with result ‘exit code’
I then run through the whole process of formating my drive, re-installing JetPack 6 and repeat. Have done this 5 times now. It fails everytime after a reboot. There are software updates and one of them is docker-ce. I tried not installing any docker component on my last cycle to see if that was the issue. It still failed.
I have two ubuntu errors after reboot. Package nvidia-l4t-nvpmodel 36.2.0-2023121821 and package tracker-extract 3.3.3-0ubuntu0.20.04.1
Any ideas?
