I have just flashed my Jetson TX2 with JetPack 4.6.1 on L4T 32.7.1. I had to do this using a custom build and then manually flashing, rather than using the SDK manager. I used the Ubuntu 18.04.5 base image for my root file system, and installed the required packages on top of it such that activate_binaries.sh succeeded.
However, when I tried to install and run Docker on the Jetson following these instructions: Installation Guide — NVIDIA Cloud Native Technologies documentation, I am unable to get past the step of installing docker-ce. The daemon fails to start with the following error:
failed to start daemon: error initializing graphdriver: devicemapper: Error running deviceCreate (CreatePool) dm_task_run failed
And when I run “dmesg” I see this:
[ 92.235768] device-mapper: ioctl: error adding target to table
[ 94.732327] device-mapper: table: 253:0: thin-pool: unknown target type
[ 94.739095] device-mapper: ioctl: error adding target to table
[ 97.227228] device-mapper: table: 253:0: thin-pool: unknown target type
[ 97.233972] device-mapper: ioctl: error adding target to table
[ 99.719035] device-mapper: table: 253:0: thin-pool: unknown target type
[ 99.726338] device-mapper: ioctl: error adding target to table
[ 633.934664] device-mapper: table: 253:0: thin-pool: unknown target type
[ 633.941317] device-mapper: ioctl: error adding target to table
I have run Docker’s check-config.sh and everything that is listed as required shows as present, as well as the kernel requirements for devicemapper except for “CONFIG_DM_THIN_PROVISIONING” which is shown as “missing.” However, I did not enable this on my previous kernel build (which ran L4T 32.2), and Docker ran fine on that version.
I have tried using overlay2 as well, but Docker claims it does not exist.
