Docker instantiation failed with error: 500 Server Error: Internal Server Error ("OCI runtime create failed...)
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-06-12 13:03:33,305 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-06-12 13:03:33,309 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-06-12 13:03:33,375 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4185: The name tf.truncated_normal is deprecated. Please use tf.random.truncated_normal instead.
2021-06-12 13:03:34,909 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4185: The name tf.truncated_normal is deprecated. Please use tf.random.truncated_normal instead.
Initialize optimizer
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-06-12 13:03:38,041 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-06-12 13:03:38,042 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-06-12 13:03:39,009 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2021-06-12 13:03:40,113 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/architecture/ssd_loss.py:87: The name tf.log is deprecated. Please use tf.math.log instead.
2021-06-12 13:03:40,142 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/architecture/ssd_loss.py:87: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/tensor_utils.py:121: The name tf.local_variables_initializer is deprecated. Please use tf.compat.v1.local_variables_initializer instead.
2021-06-12 13:03:40,270 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/tensor_utils.py:121: The name tf.local_variables_initializer is deprecated. Please use tf.compat.v1.local_variables_initializer instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/tensor_utils.py:122: The name tf.tables_initializer is deprecated. Please use tf.compat.v1.tables_initializer instead.
2021-06-12 13:03:40,271 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/tensor_utils.py:122: The name tf.tables_initializer is deprecated. Please use tf.compat.v1.tables_initializer instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/tensor_utils.py:123: The name tf.get_collection is deprecated. Please use tf.compat.v1.get_collection instead.
2021-06-12 13:03:40,271 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/tensor_utils.py:123: The name tf.get_collection is deprecated. Please use tf.compat.v1.get_collection instead.
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
Input (InputLayer)              (None, 3, 300, 300)  0
conv1 (Conv2D)                  (None, 64, 150, 150) 9408        Input[0][0]
bn_conv1 (BatchNormalization)   (None, 64, 150, 150) 256         conv1[0][0]
activation_1 (Activation)       (None, 64, 150, 150) 0           bn_conv1[0][0]
block_1a_conv_1 (Conv2D)        (None, 64, 75, 75)   36864       activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 75, 75)   256         block_1a_conv_1[0][0]
block_1a_relu_1 (Activation)    (None, 64, 75, 75)   0           block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D)        (None, 64, 75, 75)   36864       block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 75, 75)   4096        activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 75, 75)   256         block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 75, 75)   256         block_1a_conv_shortcut[0][0]
add_1 (Add)                     (None, 64, 75, 75)   0           block_1a_bn_2[0][0]
        block_1a_bn_shortcut[0][0]
block_1a_relu (Activation)      (None, 64, 75, 75)   0           add_1[0][0]
block_1b_conv_1 (Conv2D)        (None, 64, 75, 75)   36864       block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 75, 75)   256         block_1b_conv_1[0][0]
block_1b_relu_1 (Activation)    (None, 64, 75, 75)   0           block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D)        (None, 64, 75, 75)   36864       block_1b_relu_1[0][0]
block_1b_conv_shortcut (Conv2D) (None, 64, 75, 75)   4096        block_1a_relu[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 75, 75)   256         block_1b_conv_2[0][0]
block_1b_bn_shortcut (BatchNorm (None, 64, 75, 75)   256         block_1b_conv_shortcut[0][0]
add_2 (Add)                     (None, 64, 75, 75)   0           block_1b_bn_2[0][0]
        block_1b_bn_shortcut[0][0]
block_1b_relu (Activation)      (None, 64, 75, 75)   0           add_2[0][0]
block_2a_conv_1 (Conv2D)        (None, 128, 38, 38)  73728       block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 38, 38)  512         block_2a_conv_1[0][0]
block_2a_relu_1 (Activation)    (None, 128, 38, 38)  0           block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D)        (None, 128, 38, 38)  147456      block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 38, 38)  8192        block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 38, 38)  512         block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 38, 38)  512         block_2a_conv_shortcut[0][0]
add_3 (Add)                     (None, 128, 38, 38)  0           block_2a_bn_2[0][0]
        block_2a_bn_shortcut[0][0]
block_2a_relu (Activation)      (None, 128, 38, 38)  0           add_3[0][0]
block_2b_conv_1 (Conv2D)        (None, 128, 38, 38)  147456      block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 38, 38)  512         block_2b_conv_1[0][0]
block_2b_relu_1 (Activation)    (None, 128, 38, 38)  0           block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D)        (None, 128, 38, 38)  147456      block_2b_relu_1[0][0]
block_2b_conv_shortcut (Conv2D) (None, 128, 38, 38)  16384       block_2a_relu[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 38, 38)  512         block_2b_conv_2[0][0]
block_2b_bn_shortcut (BatchNorm (None, 128, 38, 38)  512         block_2b_conv_shortcut[0][0]
add_4 (Add)                     (None, 128, 38, 38)  0           block_2b_bn_2[0][0]
        block_2b_bn_shortcut[0][0]
block_2b_relu (Activation)      (None, 128, 38, 38)  0           add_4[0][0]
block_3a_conv_1 (Conv2D)        (None, 256, 19, 19)  294912      block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 19, 19)  1024        block_3a_conv_1[0][0]
block_3a_relu_1 (Activation)    (None, 256, 19, 19)  0           block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D)        (None, 256, 19, 19)  589824      block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 19, 19)  32768       block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 19, 19)  1024        block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 19, 19)  1024        block_3a_conv_shortcut[0][0]
add_5 (Add)                     (None, 256, 19, 19)  0           block_3a_bn_2[0][0]
        block_3a_bn_shortcut[0][0]
block_3a_relu (Activation)      (None, 256, 19, 19)  0           add_5[0][0]
block_3b_conv_1 (Conv2D)        (None, 256, 19, 19)  589824      block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 19, 19)  1024        block_3b_conv_1[0][0]
block_3b_relu_1 (Activation)    (None, 256, 19, 19)  0           block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D)        (None, 256, 19, 19)  589824      block_3b_relu_1[0][0]
block_3b_conv_shortcut (Conv2D) (None, 256, 19, 19)  65536       block_3a_relu[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 19, 19)  1024        block_3b_conv_2[0][0]
block_3b_bn_shortcut (BatchNorm (None, 256, 19, 19)  1024        block_3b_conv_shortcut[0][0]
add_6 (Add)                     (None, 256, 19, 19)  0           block_3b_bn_2[0][0]
        block_3b_bn_shortcut[0][0]
block_3b_relu (Activation)      (None, 256, 19, 19)  0           add_6[0][0]
block_4a_conv_1 (Conv2D)        (None, 512, 19, 19)  1179648     block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 19, 19)  2048        block_4a_conv_1[0][0]
block_4a_relu_1 (Activation)    (None, 512, 19, 19)  0           block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D)        (None, 512, 19, 19)  2359296     block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 19, 19)  131072      block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 19, 19)  2048        block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 19, 19)  2048        block_4a_conv_shortcut[0][0]
add_7 (Add)                     (None, 512, 19, 19)  0           block_4a_bn_2[0][0]
        block_4a_bn_shortcut[0][0]
block_4a_relu (Activation)      (None, 512, 19, 19)  0           add_7[0][0]
block_4b_conv_1 (Conv2D)        (None, 512, 19, 19)  2359296     block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 19, 19)  2048        block_4b_conv_1[0][0]
block_4b_relu_1 (Activation)    (None, 512, 19, 19)  0           block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D)        (None, 512, 19, 19)  2359296     block_4b_relu_1[0][0]
block_4b_conv_shortcut (Conv2D) (None, 512, 19, 19)  262144      block_4a_relu[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 19, 19)  2048        block_4b_conv_2[0][0]
block_4b_bn_shortcut (BatchNorm (None, 512, 19, 19)  2048        block_4b_conv_shortcut[0][0]
add_8 (Add)                     (None, 512, 19, 19)  0           block_4b_bn_2[0][0]
        block_4b_bn_shortcut[0][0]
block_4b_relu (Activation)      (None, 512, 19, 19)  0           add_8[0][0]
ssd_expand_block_0_conv_0 (Conv (None, 256, 19, 19)  131328      block_4b_relu[0][0]
ssd_expand_block_0_relu_0 (ReLU (None, 256, 19, 19)  0           ssd_expand_block_0_conv_0[0][0]
ssd_expand_block_0_conv_1 (Conv (None, 256, 19, 19)  589824      ssd_expand_block_0_relu_0[0][0]
ssd_expand_block_0_bn_1 (BatchN (None, 256, 19, 19)  1024        ssd_expand_block_0_conv_1[0][0]
ssd_expand_block_0_relu_1 (ReLU (None, 256, 19, 19)  0           ssd_expand_block_0_bn_1[0][0]
ssd_expand_block_1_conv_0 (Conv (None, 128, 19, 19)  32896       ssd_expand_block_0_relu_1[0][0]
ssd_expand_block_1_relu_0 (ReLU (None, 128, 19, 19)  0           ssd_expand_block_1_conv_0[0][0]
ssd_expand_block_1_conv_1 (Conv (None, 256, 10, 10)  294912      ssd_expand_block_1_relu_0[0][0]
ssd_expand_block_1_bn_1 (BatchN (None, 256, 10, 10)  1024        ssd_expand_block_1_conv_1[0][0]
ssd_expand_block_1_relu_1 (ReLU (None, 256, 10, 10)  0           ssd_expand_block_1_bn_1[0][0]
ssd_expand_block_2_conv_0 (Conv (None, 64, 10, 10)   16448       ssd_expand_block_1_relu_1[0][0]
ssd_expand_block_2_relu_0 (ReLU (None, 64, 10, 10)   0           ssd_expand_block_2_conv_0[0][0]
ssd_expand_block_2_conv_1 (Conv (None, 128, 5, 5)    73728       ssd_expand_block_2_relu_0[0][0]
ssd_expand_block_2_bn_1 (BatchN (None, 128, 5, 5)    512         ssd_expand_block_2_conv_1[0][0]
ssd_expand_block_2_relu_1 (ReLU (None, 128, 5, 5)    0           ssd_expand_block_2_bn_1[0][0]
ssd_expand_block_3_conv_0 (Conv (None, 64, 5, 5)     8256        ssd_expand_block_2_relu_1[0][0]
ssd_expand_block_3_relu_0 (ReLU (None, 64, 5, 5)     0           ssd_expand_block_3_conv_0[0][0]
ssd_expand_block_3_conv_1 (Conv (None, 128, 3, 3)    73728       ssd_expand_block_3_relu_0[0][0]
ssd_expand_block_3_bn_1 (BatchN (None, 128, 3, 3)    512         ssd_expand_block_3_conv_1[0][0]
ssd_expand_block_3_relu_1 (ReLU (None, 128, 3, 3)    0           ssd_expand_block_3_bn_1[0][0]
ssd_expand_block_4_conv_0 (Conv (None, 64, 3, 3)     8256        ssd_expand_block_3_relu_1[0][0]
ssd_expand_block_4_relu_0 (ReLU (None, 64, 3, 3)     0           ssd_expand_block_4_conv_0[0][0]
ssd_expand_block_4_conv_1 (Conv (None, 128, 2, 2)    73728       ssd_expand_block_4_relu_0[0][0]
ssd_expand_block_4_bn_1 (BatchN (None, 128, 2, 2)    512         ssd_expand_block_4_conv_1[0][0]
ssd_expand_block_4_relu_1 (ReLU (None, 128, 2, 2)    0           ssd_expand_block_4_bn_1[0][0]
ssd_conf_0 (Conv2D)             (None, 8, 38, 38)    9224        block_2b_relu[0][0]
ssd_conf_1 (Conv2D)             (None, 8, 19, 19)    18440       ssd_expand_block_0_relu_1[0][0]
ssd_conf_2 (Conv2D)             (None, 8, 10, 10)    18440       ssd_expand_block_1_relu_1[0][0]
ssd_conf_3 (Conv2D)             (None, 8, 5, 5)      9224        ssd_expand_block_2_relu_1[0][0]
ssd_conf_4 (Conv2D)             (None, 8, 3, 3)      9224        ssd_expand_block_3_relu_1[0][0]
ssd_conf_5 (Conv2D)             (None, 12, 2, 2)     13836       ssd_expand_block_4_relu_1[0][0]
permute_1 (Permute)             (None, 38, 38, 8)    0           ssd_conf_0[0][0]
permute_2 (Permute)             (None, 19, 19, 8)    0           ssd_conf_1[0][0]
permute_3 (Permute)             (None, 10, 10, 8)    0           ssd_conf_2[0][0]
permute_4 (Permute)             (None, 5, 5, 8)      0           ssd_conf_3[0][0]
permute_5 (Permute)             (None, 3, 3, 8)      0           ssd_conf_4[0][0]
permute_6 (Permute)             (None, 2, 2, 12)     0           ssd_conf_5[0][0]
conf_reshape_0 (Reshape)        (None, 5776, 1, 2)   0           permute_1[0][0]
conf_reshape_1 (Reshape)        (None, 1444, 1, 2)   0           permute_2[0][0]
conf_reshape_2 (Reshape)        (None, 400, 1, 2)    0           permute_3[0][0]
conf_reshape_3 (Reshape)        (None, 100, 1, 2)    0           permute_4[0][0]
conf_reshape_4 (Reshape)        (None, 36, 1, 2)     0           permute_5[0][0]
conf_reshape_5 (Reshape)        (None, 24, 1, 2)     0           permute_6[0][0]
mbox_conf (Concatenate)         (None, 7780, 1, 2)   0           conf_reshape_0[0][0]
        conf_reshape_1[0][0]
        conf_reshape_2[0][0]
        conf_reshape_3[0][0]
        conf_reshape_4[0][0]
        conf_reshape_5[0][0]
ssd_loc_0 (Conv2D)              (None, 16, 38, 38)   18448       block_2b_relu[0][0]
ssd_loc_1 (Conv2D)              (None, 16, 19, 19)   36880       ssd_expand_block_0_relu_1[0][0]
ssd_loc_2 (Conv2D)              (None, 16, 10, 10)   36880       ssd_expand_block_1_relu_1[0][0]
ssd_loc_3 (Conv2D)              (None, 16, 5, 5)     18448       ssd_expand_block_2_relu_1[0][0]
ssd_loc_4 (Conv2D)              (None, 16, 3, 3)     18448       ssd_expand_block_3_relu_1[0][0]
ssd_loc_5 (Conv2D)              (None, 24, 2, 2)     27672       ssd_expand_block_4_relu_1[0][0]
before_softmax_permute (Permute (None, 2, 1, 7780)   0           mbox_conf[0][0]
permute_7 (Permute)             (None, 38, 38, 16)   0           ssd_loc_0[0][0]
permute_8 (Permute)             (None, 19, 19, 16)   0           ssd_loc_1[0][0]
permute_9 (Permute)             (None, 10, 10, 16)   0           ssd_loc_2[0][0]
permute_10 (Permute)            (None, 5, 5, 16)     0           ssd_loc_3[0][0]
permute_11 (Permute)            (None, 3, 3, 16)     0           ssd_loc_4[0][0]
permute_12 (Permute)            (None, 2, 2, 24)     0           ssd_loc_5[0][0]
ssd_anchor_0 (AnchorBoxes)      (None, 1444, 4, 8)   0           ssd_loc_0[0][0]
ssd_anchor_1 (AnchorBoxes)      (None, 361, 4, 8)    0           ssd_loc_1[0][0]
ssd_anchor_2 (AnchorBoxes)      (None, 100, 4, 8)    0           ssd_loc_2[0][0]
ssd_anchor_3 (AnchorBoxes)      (None, 25, 4, 8)     0           ssd_loc_3[0][0]
ssd_anchor_4 (AnchorBoxes)      (None, 9, 4, 8)      0           ssd_loc_4[0][0]
ssd_anchor_5 (AnchorBoxes)      (None, 4, 6, 8)      0           ssd_loc_5[0][0]
mbox_conf_softmax_ (Softmax)    (None, 2, 1, 7780)   0           before_softmax_permute[0][0]
loc_reshape_0 (Reshape)         (None, 5776, 1, 4)   0           permute_7[0][0]
loc_reshape_1 (Reshape)         (None, 1444, 1, 4)   0           permute_8[0][0]
loc_reshape_2 (Reshape)         (None, 400, 1, 4)    0           permute_9[0][0]
loc_reshape_3 (Reshape)         (None, 100, 1, 4)    0           permute_10[0][0]
loc_reshape_4 (Reshape)         (None, 36, 1, 4)     0           permute_11[0][0]
loc_reshape_5 (Reshape)         (None, 24, 1, 4)     0           permute_12[0][0]
anchor_reshape_0 (Reshape)      (None, 5776, 1, 8)   0           ssd_anchor_0[0][0]
anchor_reshape_1 (Reshape)      (None, 1444, 1, 8)   0           ssd_anchor_1[0][0]
anchor_reshape_2 (Reshape)      (None, 400, 1, 8)    0           ssd_anchor_2[0][0]
anchor_reshape_3 (Reshape)      (None, 100, 1, 8)    0           ssd_anchor_3[0][0]
anchor_reshape_4 (Reshape)      (None, 36, 1, 8)     0           ssd_anchor_4[0][0]
anchor_reshape_5 (Reshape)      (None, 24, 1, 8)     0           ssd_anchor_5[0][0]
mbox_conf_softmax (Permute)     (None, 7780, 1, 2)   0           mbox_conf_softmax_[0][0]
mbox_loc (Concatenate)          (None, 7780, 1, 4)   0           loc_reshape_0[0][0]
        loc_reshape_1[0][0]
        loc_reshape_2[0][0]
        loc_reshape_3[0][0]
        loc_reshape_4[0][0]
        loc_reshape_5[0][0]
mbox_priorbox (Concatenate)     (None, 7780, 1, 8)   0           anchor_reshape_0[0][0]
        anchor_reshape_1[0][0]
        anchor_reshape_2[0][0]
        anchor_reshape_3[0][0]
        anchor_reshape_4[0][0]
        anchor_reshape_5[0][0]
concatenate_1 (Concatenate)     (None, 7780, 1, 14)  0           mbox_conf_softmax[0][0]
        mbox_loc[0][0]
        mbox_priorbox[0][0]
ssd_predictions (Reshape)       (None, 7780, 14)     0           concatenate_1[0][0]
Total params: 13,084,316
Trainable params: 13,061,468
Non-trainable params: 22,848
2021-06-12 13:03:40,535 [INFO] __main__: Number of images in the training dataset:       24600
2021-06-12 13:03:40,535 [INFO] __main__: Number of images in the validation dataset:       360
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/scripts/train.py", line 313, in <module>
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/scripts/train.py", line 309, in main
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/scripts/train.py", line 156, in run_experiment
FileNotFoundError: [Errno 2] No such file or directory: '/workspace/Work/Crowd-Detection/ouput/weights'
  File "/usr/local/bin/ssd", line 8, in <module>
    sys.exit(main())
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/entrypoint/ssd.py", line 12, in main
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py", line 296, in launch_job
AssertionError: Process run failed.
Please $mkdir the ouput folder under your local directory.
Then the path inside the docker /workspace/Work/Crowd-Detection/ouput/ should be available.
The output file already exists in the local directory and inside the docker workspace.
Also, Is it a problem that the layers are not connected to equal layer?
No, the error is not related to the layers.
It is a common error. Need to mkdir -p the folder.
You can refer to the jupyter notebooks for ssd.
!mkdir -p $LOCAL_EXPERIMENT_DIR/experiment_dir_unpruned
!tlt ssd train --gpus 1 --gpu_index=$GPU_INDEX
-e $SPECS_DIR/ssd_train_resnet18_kitti.txt
-r $USER_EXPERIMENT_DIR/experiment_dir_unpruned
-k $KEY
-m $USER_EXPERIMENT_DIR/pretrained_resnet18/tlt_pretrained_object_detection_vresnet18/resnet_18.hdf5
The problem still occurs after doing mkdir -p the folder.
It seems to be looking for a weights file inside the output folder is this something I need to make?
Please mkdir -p xxx/output/weights to check if it helps.
It makes no difference, unfortunately.
What is the training command line?
To narrow down, can you also login the docker and try to train?
I ended up fixing the problem by reinstalling each part and ensuring they worked one at a time.
I created a guide of the process which I will leave below:
Setting up the NVIDA tlt launcher
This will assume that you have nothing pre-installed
Pre-requisites
Firstly follow one of the following guides from Ubuntu or Nvidia to setup Microsft Windows Insider Program, WSL2, NVIDIA drivers, docker and nvidia-docker2.
Both guides cover the same information but use slightly different commands so if one doesn’t work try the other.
For the tlt launcher to use docker it needs to be able to run without needing sudo every time. To achieve this follow this guide from Docker.
To pull the tlt information you need to have make and login into docker and NGC account.
After creating a docker account from docker run:
$ docker login
and enter your login information
After creating an NGC account from NGC click onto setup then generate a API key then run:
$ docker login nvcr.io
and enter “$outhtoken” as the username and the API key as the password
Extra notes:
  • I had to choose the Dev Channel in the Windows Insider Program to get the needed update
  • NVIDIA Container Toolkit does not yet support Docker Desktop WSL 2 backend so make sure to install it into WSL2
  • Run the examples in the guides to make sure everything at this stage is working as intended
Installing the launcher
Follow the NVIDIA guide to install the TLT launcher
Ensure it is working by running:
$ tlt detectnet_v2 --help
With the expected outcome as:
Using TensorFlow backend.
usage: detectnet_v2 [-h] [--gpus GPUS] [--gpu_index GPU_INDEX [GPU_INDEX ...]]
                   [--use_amp] [--log_file LOG_FILE]
                   {calibration_tensorfile,dataset_convert,evaluate,export,inference,prune,train}
Transfer Learning Toolkit
optional arguments:
-h, --help            show this help message and exit
--gpus GPUS           The number of GPUs to be used for the job.
                     The indices of the GPU's to be used.
--use_amp             Flag to enable Auto Mixed Precision.
--log_file LOG_FILE   Path to the output log file.
tasks:
Extra notes:
  • Make sure that you start docker with sudo service docker start before running the launcher
Configuring the launcher
The tlt launcher uses the file ~/.tlt_mounts.json to map the drives/mount points to the docker container it is running and is specified by NVIDIA here
To create and open the file run the following commands:
$ cd ~/
$ sudo touch .tlt_mounts.json
$ code .tlt_mounts.json
Where code can be replaced by your text editor of choice.
Next copy the example file from the NVIDA website into the file and edit the paths so that the source is the full path to the files and the destination is into a workspace that contains all the files needed.
For example:
    "Mounts": [
	    "source": "/mnt/c/Users/USERNAME/project_dir",
            "destination": "/workspace/project_dir"
            "source": "/mnt/c/Users/USERNAME/project_dir/output",
            "destination": "/workspace/project_dir/output"
            "source": "/mnt/c/Users/USERNAME/project_dir/SPEC.txt",
            "destination": "/workspace/project_dir/SPEC.txt"
Where all the information for the project is contained within “project_dir”
Creating a specification file
To train the model you need a specification file as shown by NVDIA here
To create one either copy the example or go over the different sections and set the values to what you require.
Extra notes:
  • The specification file I used is this
  • batch_size is not shown in the section for Evaluation Config but is required for the training to run
  • The directory to the labels and images should be from the workspace as specified in your ~/.tlt_mounts.json file
Running the training
Information on training the Model can be found here
The directories should be of inside the workspace as specified in your ~/.tlt_mounts.json file and the specification file.
For example the following command would apply to the directories used in the example ~/.tlt_mounts.json file
$ tlt ssd train -e /workspace/project_dir/SPEC.txt -r /workspace/project_dir/output -k KEY
Where KEY can be changed.
If training crashes due to a lack of memory lower the “batch_size” and “batch_size_per_gpu” but keep them in a value of 2^n (2, 4, 8, 16, e.c.t)
Bug fixing
Some of the problems that I discovered and how I fixed them are described bellow
When running sudo docker run --rm --gpus all nvidia/cuda:11.0-base nvidia-smi and getting the error:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:380: starting container process caused: exec: "nvidia-smi"
: executable file not found in $PATH: unknown.
Run the following lines:
$ cp /usr/lib/wsl/lib/nvidia-smi /usr/bin/nvidia-smi
$ chmod ogu+x /usr/bin/nvidia-smi
Thanks for your sharing! Really appreciate your work!
BTW, you were training with TLT 3.0-dp ,right? Did you ever try TLT3.0 ?
