docker login or pull nvcr.io Failed !!!
I can use docker search normally,but when I log in to nvcr.io or pull clara, I get this error.‘Client.Timeout exceeded while awaiting headers’
root@amax:/home/ia# cat /etc/docker/daemon.json
  "registry-mirrors": ["https://docker.mirrors.ustc.edu.cn","https://registry.docker-cn.com"],
  "insecure-registries":["nvcr.io"]
Finaly, using the following mirror source, I can download clara, but only v1 version, do your mirror repositories need special VPN ?
docker pull pengbol/nvidia-clara-train-sdk-original:v1.1-py3
Can you find a way to make NGC accessible in China?
Hi
Thanks for your interest in clara train. You don’t need to login NGC any more to pull the container. Also please try pulling the new clara train container V2 using
docker pull nvcr.io/nvidia/clara-train-sdk:v2.0
Please let us know if you face any errors.
Thanks for your answer, I tried it according to your method and got the following error.
ia@amax:~$ docker pull nvcr.io/nvidia/clara-train-sdk:v2.0
Error response from daemon: error unmarshalling content: invalid character '<' looking for beginning of value
Is this because I can’t access your server locally?
This time I can log in successfully
ia@amax:~$ docker login -u=$oauthtoken -p=jjXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXjck nvcr.io
WARNING! Using --password via the CLI is insecure. Use --password-stdin.
WARNING! Your password will be stored unencrypted in /home/ia/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
Which version of docker are you currently running?
could you please try the interactive method to login nvcr.io?
$ docker login nvcr.io
Username: $oauthtoken
Password: your API_KEY generated on NGC
I can login NGC with this method and pull nvcr.io/nvidia/clara-train-sdk:v2.0 successfully in China.
Thanks for your reply.
Finally, i find it dues to the firewall in my company, i can login in my home.
