Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Other (please specify): Docker
GPU Information
- Model: NVIDIA RTX 6000 Ada
- Driver Version: 535.230.02
Topic Description ROS2 Humble install fails when trying to install within nvcr.io/nvidia/isaac-sim:4.5.0 docker container
Detailed Description
I’m trying to install ros2 humble within the nvcr.io/nvidia/isaac-sim:4.5.0 docker container. Simply following the install tutorial, including setup, step by step, results in an installation error about libfreetype6-dev
when trying to install ros-humble-desktop.
root@wildfire-inferno:/isaac-sim# apt install ros-humble-desktop
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:The following packages have unmet dependencies:
libvtk9-dev : Depends: libfreetype6-dev
libxft-dev : Depends: libfontconfig1-dev
ros-humble-rviz-ogre-vendor : Depends: libfreetype6-dev
E: Unable to correct problems, you have held broken packages.
If you try to install libfreetype6-dev
, the following error occurs:
root@wildfire-inferno:/isaac-sim# apt install libfreetype6-dev libfontconfig1-dev
libbrotli-dev : Depends: libbrotli1 (= 1.0.9-2build6) but 1.1.0-2+ubuntu22.04.1+deb.sury.org+1 is to be installed
It seems there’s some version incompatibility
Steps to Reproduce
docker pull nvcr.io/nvidia/isaac-sim:4.5.0
docker run --name isaac-sim --entrypoint bash -it --runtime=nvidia --gpus all -e "ACCEPT_EULA=Y" --rm --network=host \ -e "PRIVACY_CONSENT=Y" \ -v ~/docker/isaac-sim/cache/kit:/isaac-sim/kit/cache:rw \ -v ~/docker/isaac-sim/cache/ov:/root/.cache/ov:rw \ -v ~/docker/isaac-sim/cache/pip:/root/.cache/pip:rw \ -v ~/docker/isaac-sim/cache/glcache:/root/.cache/nvidia/GLCache:rw \ -v ~/docker/isaac-sim/cache/computecache:/root/.nv/ComputeCache:rw \ -v ~/docker/isaac-sim/logs:/root/.nvidia-omniverse/logs:rw \ -v ~/docker/isaac-sim/data:/root/.local/share/ov/data:rw \ -v ~/docker/isaac-sim/documents:/root/Documents:rw \ nvcr.io/nvidia/isaac-sim:4.5.0
- Follow the ROS2 Humble installation steps
- Error above
Error Messages
See above
