Does anyone have any information about installing Docker on the TX2. When I run “sudo apt install docker.io” I get this error.
Job for docker.service failed because the control process exited with error code. See "systemctl status docker.service" and "journalctl -xe" for details.
invoke-rc.d: initscript docker, action "start" failed.
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2017-03-20 02:15:34 UTC; 12ms ago
Docs: https://docs.docker.com
Process: 17303 ExecStart=/usr/bin/dockerd -H fd:// $DOCKER_OPTS (code=exited, status=1/FAILURE)
Main PID: 17303 (code=exited, status=1/FAILURE)
Mar 20 02:15:33 tegra-ubuntu systemd[1]: Starting Docker Application Container Engine...
Mar 20 02:15:33 tegra-ubuntu dockerd[17303]: time="2017-03-20T02:15:33.521844000Z" level=info msg="libcontainerd: new containerd process, pid: 17310"
Mar 20 02:15:34 tegra-ubuntu dockerd[17303]: time="2017-03-20T02:15:34.527480000Z" level=warning msg="unable to modify root key limit, number of containers could be limitied by this quota:...or directory"
Mar 20 02:15:34 tegra-ubuntu dockerd[17303]: time="2017-03-20T02:15:34.554898000Z" level=error msg="'overlay' not found as a supported filesystem on this host. Please ensure kernel is new ...port loaded."
Mar 20 02:15:34 tegra-ubuntu dockerd[17303]: time="2017-03-20T02:15:34.558660000Z" level=error msg="There are no more loopback devices available."
Mar 20 02:15:34 tegra-ubuntu dockerd[17303]: time="2017-03-20T02:15:34.559010000Z" level=fatal msg="Error starting daemon: error initializing graphdriver: loopback attach failed"
Mar 20 02:15:34 tegra-ubuntu systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Mar 20 02:15:34 tegra-ubuntu systemd[1]: Failed to start Docker Application Container Engine.
Mar 20 02:15:34 tegra-ubuntu systemd[1]: docker.service: Unit entered failed state.
Mar 20 02:15:34 tegra-ubuntu systemd[1]: docker.service: Failed with result 'exit-code'.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: error processing package docker.io (--configure):
subprocess installed post-installation script returned error exit status 1
Processing triggers for systemd (229-4ubuntu16) ...
Errors were encountered while processing:
docker.io
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any idea on how to fix this?
