I have logged into nvcr.io using oauth but however:
“Unable to find image ‘isaac_ros_dev-aarch64:latest’ locally
docker: Error response from daemon: pull access denied for isaac_ros_dev-aarch64, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied.”
I also have tried to pull other ros images from nvcr.io without success.
here is my nvcr login:
can@agx:~/isaac_ros_common$ docker login nvcr.io
Authenticating with existing credentials…
WARNING! Your password will be stored unencrypted in /home/can/.docker/config.json.
Configure a credential helper to remove this warning. See
docker login | Docker Documentation
Login Succeeded
Is there a problem with the repository? Or do I need extra permissions for access?
Best Regards,
C
