Docker pull failed. 500 Server Error: Internal Server Error
I am trying to pull the gen_trt_engine:
!tao deploy faster_rcnn gen_trt_engine --gpu_index $GPU_INDEX \
                        -m $USER_EXPERIMENT_DIR/modelx.onnx \
                        -e $SPECS_DIR/default_spec_resnet50-birds_updated.txt \
                        --data_type fp32 \
                        --batch_size 8 \
                        --max_batch_size 4 \
                        --engine_file $USER_EXPERIMENT_DIR/trt.fp32.engine \
                        --results_dir $USER_EXPERIMENT_DIR/
But I am getting this error:
2024-03-07 15:07:03,968 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2024-03-07 15:07:04,043 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 360: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-deploy
2024-03-07 15:07:06,714 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 296: The required docker doesn't exist locally/the manifest has changed. Pulling a new docker.
2024-03-07 15:07:06,714 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 155: Pulling the required container. This may take several minutes if you're doing this for the first time. Please wait here.
Pulling from repository: nvcr.io/nvidia/tao/tao-toolkit
Docker pull failed. 500 Server Error: Internal Server Error ("Head "https://nvcr.io/v2/nvidia/tao/tao-toolkit/manifests/5.0.0-deploy": unauthorized: authentication required")
What I tried so far:
  • Upgraded the TAO toolkit version: bash setup/quickstart_launcher.sh --upgrade
  • Restared my machine.
  • docker login nvcr.io seems to work.
  • docker pull nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.5-py3 gives this error:
    Error response from daemon: Head "https://nvcr.io/v2/nvidia/tao/tao-toolkit-tf/manifests/v3.22.05-tf1.15.5-py3": unauthorized: authentication required
tao info --verbose
Configuration of the TAO Toolkit Instance
task_group:
    model:
        dockers:
                5.0.0-tf2.11.0:
                    docker_registry: nvcr.io
                    tasks:
                        1. classification_tf2
                        2. efficientdet_tf2
                5.0.0-tf1.15.5:
                    tasks:
                        1. bpnet
                        2. classification_tf1
                        3. converter
                        4. detectnet_v2
                        5. dssd
                        6. efficientdet_tf1
                        7. faster_rcnn
                        8. fpenet
                        9. lprnet
                        10. mask_rcnn
                        11. multitask_classification
                        12. retinanet
                        13. ssd
                        14. unet
                        15. yolo_v3
                        16. yolo_v4
                        17. yolo_v4_tiny
                5.2.0-pyt2.1.0:
                    tasks:
                        1. action_recognition
                        2. centerpose
                        3. deformable_detr
                        4. dino
                        5. mal
                        6. ml_recog
                        7. ocdnet
                        8. ocrnet
                        9. optical_inspection
                        10. pointpillars
                        11. pose_classification
                        12. re_identification
                        13. visual_changenet
                5.2.0.1-pyt1.14.0:
                    tasks:
                        1. classification_pyt
                        2. segformer
    dataset:
        dockers:
                5.2.0-data-services:
                    tasks:
                        1. augmentation
                        2. auto_label
                        3. annotations
                        4. analytics
    deploy:
        dockers:
                5.2.0-deploy:
                    tasks:
                        1. visual_changenet
                        2. centerpose
                        3. classification_pyt
                        4. classification_tf1
                        5. classification_tf2
                        6. deformable_detr
                        7. detectnet_v2
                        8. dino
                        9. dssd
                        10. efficientdet_tf1
                        11. efficientdet_tf2
                        12. faster_rcnn
                        13. lprnet
                        14. mask_rcnn
                        15. ml_recog
                        16. multitask_classification
                        17. ocdnet
                        18. ocrnet
                        19. optical_inspection
                        20. retinanet
                        21. segformer
                        22. ssd
                        23. trtexec
                        24. unet
                        25. yolo_v3
                        26. yolo_v4
                        27. yolo_v4_tiny
format_version: 3.0
toolkit_version: 5.2.0.1
published_date: 01/16/2024
It seems that I should have used the API key rather than the Personal Key. When I logged in again with the API key, I am able to pull.
