I am able to get the deepstream samples work, but not the python samples
# allow root to access X Server to display output from inside the docker container
$ xhost +si:localuser:root
$ docker run -it --rm --net=host --gpus all -e DISPLAY=$DISPLAY --device /dev/snd -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream:6.3-samples
$ cd samples
$ deepstream-app -c configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
but cloning this into sources
and following the section Running the samples inside DeepStream SDK docker
Just gives me
python3 deepstream_test_1.py
File "deepstream_test_1.py", line 29, in <module>
import pyds
ModuleNotFoundError: No module named 'pyds'
and trying to install the bindings has not been succesful since not even pip is there in the first place. I got it installed, but ran into a lot of other problems trying to install the compiled bindings from
$ pip3 install pyds-1.1.8-py3-none-linux_x86_64.whl
Failed to build pycairo
ERROR: Could not build wheels for pycairo, which is required to install pyproject.toml-based projects
What are the best way to run the python deepstream samples in docker?
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/pytypes.h:12,
from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/cast.h:13,
from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/attr.h:13,
from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/pybind11.h:44,
from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bind_string_property_definitions.h:18,
from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindgstnvdsmeta.cpp:20:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/detail/common.h:112:10: fatal error: Python.h: No such file or directory
112 | #include <Python.h>
compilation terminated.
Do you know why I get this error now? :)
What are the steps to get this samples running in docker?
If you run it one day earlier, it should be ok :)
DS-6.4 has just been released, so the master corresponds to DS-6.4.
If you continue to use 6.3-triton-multiarch, the correct branch should be v1.1.8.
