Docker run error on home automation with jetson and deepstack
I am following the Jetson Community Projects | NVIDIA Developer
And the Read me at
GitHub - robmarkcole/HASS-Deepstack-object: Home Assistant custom component for using Deepstack object detection
I am running the below command on jetson xavier nx development kit
docker run -e VISION-DETECTION=True -e API-KEY=“mysecretkey” -v localstorage:/datastore -p 80:5000 deepquestai/deepstack
I get the below mentioned error.
standard_init_linux.go:211: exec user process caused “exec format error”
Can anyone help on this issue?
This looks like a Jetson issue. Please refer to the below samlples in case useful.
For any further assistance, we recommend you to raise it to the respective platform from the below link
Hi @NVES ,
Is there any readily available application on jetson platform to run inference from live camera , using pre trained models ?
Any help is appreciated.
@vikaash.kb Have you had any success in resolving your issue? I am interested in the same.
