I have tried all four options shown on the bottom left hand and followed its instructions to either power on/off the jetson, as well as have it plugged into the host computer via USB micro-b. What might be causing the device to be undetected?
What is the command line to run this docker? Did you use --privileged option to enable usb access in the container?
After you manually put Jetson to recovery mode, can you please run lsusb command in both host and in container respectively to paste output?
Probably you could run lsusb command with the same docker image, but in a different container. sudo docker run -it --privileged -v /dev/bus/usb:/dev/bus/usb/ --entrypoint /bin/bash <sdkmanager_image_id>
However, although lsusb outputs nothing, I was able to locate directory /dev/bus/usb/002/001 and /dev/bus/usb/000/000 inside the docker container. But, they were both empty. Not sure if this is helpful.
Hi gg22,
In the document, there are additional two arguments, -v /dev:/dev -v /media/$USER:/media/nvidia:slave, can you please try if they are useful to solve the issue?
