Docker Support DriveOS 6.0.8.1
Dear @SivaRamaKrishnaNV,
Thank you. Could you please share with us in which release you plan to fix the issue?
Kind regards,
Adam
are there any updates to this?
Thank you and kind regards.
Dear @sebbe,
Could you share the used steps(may be you can share from the history command). We notice the shared steps was working for few other customers.
Dear @SivaRamaKrishnaNV ,
I can also confirm now that docker is enabled and working again on our machine thanks to @AdamBalazsVay 's post.
When following the steps in [BUG] failed to start docker container in orin target with error: failed to create endpoint on network bridge, operation not supported it is additionally needed in step 7 of kernel compiling to navigate via menuconfig to Device Drivers ---> Network device support ---> Virtual ethernet pair device and set the module to built-in (<*>).
Thank you very much for your support.
